20 Most Recent
Olympus Camedia C-460 Zoom del Sol Digital Camera Questions & Answers
How to view movies on PC
Right-click on the movie and choose the player you want to open it with. You may need to download one if you don't already have one on your computer. Quicktime is a good choice...it's a free download at apple.com.
How do i trun the flash off at night
Press cursor-right (marked with a lightning bolt) to bring up the flash menu. Press cursor-right to cycle through the flash options. The one you want is the lightning bolt in a circle with a slash through it.
Buttons do not work
You can upload pics without doing anything except turning it on.
You can turn it on, plug it in and use either media player or picture viewer or equivelant program to sync the device. Most these programs have a sync option that will take all media off camera and put it on computer. Unless you are using a sim card and have a card slot on your pc
How can i use the camedia c-460 as webcam on mac
Unfortunately there is no camera in the Olympus product line that has webcam capability. The only reason you would connect the camera to the computer in the first place is to download the photos from the picture card to your MAC hard drive.
Memory card will not lock in place on camera
well even if u get inside probably u will not be able to fix it because it´s pretty normal for the xD socket to brake and needs to replaced. anyway after u remove all the screws just pull it hard, because sometimes the cover is glued to the mainboard, the socket is on the mainboard, be careful once u open it can have loose parts from the xD socket, if u can get it t work, after just glue all that because it brakes a lot, don´t use 3 sec one because will damage the socket.... if it´s under warranty just send to the repair centre they will fix it for free....
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set
Don't use barrettes from different sets or brands together.
I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away.
Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad.
Check you are using a charger for NiMH batteries.
I would try another set (new) because buying Alkaline is also not cheap.
I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
How to use zoom on c-860L
This 14 year old camera, does not have a zoom lens. It has a 5,5 mm lens, giving it a angle of view of about a 35 mm lens of a Full frame camera. However, you should be able to zoom digital 2 times.
I can't find a manual, to help you on this, but the quality will be the same as cropping into a frame on your computer. So if you do put the pictures on a computer, you also can "zoom" in to the parts you want. Be aware a 1 megapixel camera, does not offer that much of detail.
