E-Machines... | Answered on Jan 29, 2015
E-Machines... | Answered on Dec 30, 2014
E-Machines... | Posted on Feb 04, 2014 | Be the first to answer
E-Machines... | Answered on Dec 27, 2013
E-Machines... | Answered on Dec 22, 2013
E-Machines... | Answered on Sep 07, 2013
E-Machines... | Answered on Feb 08, 2013
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
E-Machines... | Answered on Sep 07, 2012
E-Machines... | Answered on Sep 02, 2012
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) Hope this helps you
E-Machines... | Answered on Nov 25, 2011
E-Machines... | Answered on Oct 01, 2011
E-Machines... | Answered on Aug 25, 2011
E-Machines... | Answered on Aug 12, 2011
E-Machines... | Answered on Aug 04, 2011
E-Machines... | Answered on Jul 10, 2011
E-Machines... | Answered on Jun 29, 2011
E-Machines... | Answered on Apr 30, 2011
E-Machines... | Answered on Apr 08, 2011
E-Machines... | Answered on Apr 07, 2011
162 questions posted
5,011 Questions
-63 Questions
170 Questions
89 Questions
