20 Most Recent Philips 32PF9964 32 in. Television Questions & Answers
0answers
42pf7521d/10 replaced caps c8042 and c8054
www.shopjimmy.com has repair kits for many different boards. I'm sure there's one that will help you.
1/9/2014 3:07:45 AM • Philips 32PF9964... • Answered on Jan 09, 2014
Remote control work very slowly and sometime do
Please follow the troubleshooting steps:
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the buttons on the remote control are jammed.
  4. Install fresh batteries into the remote control.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV.
  6. On the remote control, press the TV FUNCTION button.
  7. Press the POWER button and other buttons to test the operation.
  8. Try using the remote control at varying distances from the TV.
  9. Power reset the TV by follow the steps:
  • Unplug the television power cord from the electrical outlet.
  • Let the television remain without power for 60 seconds.
  • Plug the power cord back into the electrical outlet.
1/9/2011 11:02:56 AM • Philips 32PF9964... • Answered on Jan 09, 2011
I have a 32 pt 66 3s37g philips tv It wont
No,U can try website like Remotes.com to buy the original remote,if u like.Take the tv aparts.The power supply board,that the board where the power a/c cord plug into it.That the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
7/11/2010 11:14:02 PM • Philips 32PF9964... • Answered on Jul 11, 2010
2answers
Phillips 32FD9944/01s - sound but no screen
your set may have blown its y sus board and i know the x sus board is part of the plasma display panel either way your looking at a very expensive repair if your not warrantied
8/20/2009 3:18:45 PM • Philips 32PF9964... • Answered on Aug 20, 2009
Clicking power supply? wont turn on
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
6/2/2009 3:18:42 PM • Philips 32PF9964... • Answered on Jun 02, 2009
Phillips 32" plasma - black vertical line
I am having similar issues...Aldottore, did you ever determine cause and find resolution?
10/9/2008 9:02:14 PM • Philips 32PF9964... • Answered on Oct 09, 2008
3answers
Problem starting a plasma
When it looks like its going to start up and it dosent then its an indication that one of the sweeps didnt start up. When you hit the power switch, the power supply sends an ok signal to start up the horizontal and vertical oscillators. When these start up they go to there respective drive circuits and then the vertical will send a signal to the power supply to keep on going so then the horizontal circuit starts up and sends an ok signal to keep going so then the set comes ob,\. If one of the two doesent start up and stay running then the power supply shuts down. To troublwe shoot these sets you need a service manualo and a good multmeter and a scope wouldnt hurt slso. This set has no user servicable parts inside of her so you need to take the set to a pro to assist you in the repair. Good Luck
10/7/2008 2:09:56 PM • Philips 32PF9964... • Answered on Oct 07, 2008
2answers
Standby LED stays red.
This can be a combination of things. The main power supply may have failed, or there is a short putting it in to protect mode. It is also possible that the back plane supply and or lamps have failed.
Jerry G.
8/11/2008 1:53:51 PM • Philips 32PF9964... • Answered on Aug 11, 2008
2answers
Part number
The part number is: 313503710591 and the cost is: $69.95. The part description is: power supply panel assembly.
Dan
7/16/2008 8:36:41 PM • Philips 32PF9964... • Answered on Jul 16, 2008
0answers
ADC ALIGNMENT TEST PATTERN FOR PHILIPS 32FD9944/01s
Just a guess but are you looking for colour gradients to set gamma etc?
There's some pages with patterns here, hope one of them fits the bill!
http://www.lynxxx.nl/barco/patterns/ http://brighamrad.harvard.edu/research/topics/vispercep/tutorial.html
http://www.drycreekphoto.com/Learn/Calibration/monitor_gradient.htm
and software
http://www.hex2bit.com/products/product_mcw.asp
11/11/2007 10:53:52 PM • Philips 32PF9964... • Answered on Nov 11, 2007
Tv STAYS IN STANDBY SOLID GREEN LIGHT TO SOLID RED
did you have a service contract with them?
if so the have to replace it.
call the manufacturer.
10/30/2007 3:06:32 AM • Philips 32PF9964... • Answered on Oct 30, 2007
Philips LCD 42PFL3603D/F7 won't stay on until I've held the power button in a few times. The display comes on, then I hear a click and it shuts off. After a few cycles of this it stays on
Remove the cover on the back of the tv. Look for swollen or leaking capacitors. They kinda look like batteries. If they are bulging or leaking then that is your problem. You will have to de-solder the old ones off. Then solder the new capacitors onto the circuit board. Capacitors will cost about 20 dollars and installing them isn't that hard to do. It will fix your tv 99% of the time. So it is worth a try!
2/21/2024 9:36:48 AM • Philips... • Answered on Feb 21, 2024
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM • Philips... • Answered on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay https://www.ebay.ca > ... > Remote Controls Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ... $67.67 · ‎In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay https://www.ebay.ca > ... > Remote Controls PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost. US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com https://www.replacementremotes.com > philips > buy-... PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM • Philips... • Answered on Dec 05, 2023
ILive Sound Bar. I need the code for Philips Universal Remote to program my iLive Sound Bar please?
Best advice here https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote So many codes, good luck with that :>)
3-Digit Codes
  • 856
  • 734
  • 837
4-Digit Codes
  • 2113
  • 3175
  • 0816
5-Digit Codes
  • 33279
  • 72303
  • 32113
  • 23175
  • 33175
  • 42113
  • 31957
  • 43175
iLive remotes https://www.google.com/search?q=iLive+Sound+Bar+replacement+remote ..
11/19/2023 4:56:05 AM • Philips... • Answered on Nov 19, 2023
Needing to upgrade software on
yes i need software upgrade APPLICATION
11/18/2023 5:21:08 PM • Philips... • Answered on Nov 18, 2023
Philips 32PF9964 32 in. Television Logo
19 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
phillips 32 plasma black vertical line
  • Televison & Video
