20 Most Recent Philips Magnavox 27MS343S 27" TV Questions & Answers
There is a language selection in the Magnavox menu, hit menu on the remote and I think it is under features.
Philips Magnavox... | Answered on Jul 16, 2019
I bought a universal remote from kmart today to try and access my tv menu to turn child lock off but all buttons are locked i need help
Philips Magnavox... | Answered on Jul 07, 2019
Did you try disconnecting the TV overnight to reset it?
Philips Magnavox... | Answered on Jul 06, 2019
Bagaimana mencari signal yg hilang pada tv led philip
Philips Magnavox... | Answered on Mar 20, 2019
To fix this, you need to do something called degaussing. You should keep magnets away from the screen in the future, because they cause this problem.
The first thing to try is to turn it on and off, making sure that all magnets and speakers (which have magnets in them) are kept far away from it. This will activate the monitor's auto-degausser if it has one. If this does not help, this guide: http://www.wikihow.com/Degauss-a-Computer-Monitor gives a couple solutions, including using a soldering gun (not a soldering iron), illustrated in the video below:
With a powerdrill:
Or investing about 60 bucks in a degaussing coil like this which is a guaranteed fix:
One other trick that might work is to take an old CRT monitor ("fat-screen" rather than "flat-screen"), hold it up to the tv screen to screen, and turn it on and off to have the monitor use its own degausser. The monitor may have a button to activate degaussing, or it may be in the menu you can bring up with the buttons on the bottom of the screen.
If you don't want to deal with any of this, a tv repair shop will degauss your tv for you quickly.
Philips Magnavox... | Answered on Sep 11, 2018
My TV is shutting off after you turn it on.Model #27MT5005D.
The light continue to blink, but thats it.
Philips Magnavox... | Answered on Mar 11, 2018
Fault with TV remote sensor section circuit is very rare.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
https://electronicshelponline.blogspot.com/
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Philips Magnavox... | Answered on Jan 21, 2018
Replace with 105deg capacitors of the SAME RATING, not larger capacity!
Philips Magnavox... | Answered on Jan 13, 2018
Wow 6ya not much of a fixer. I'll be sure to not use this website for advice ??.
Philips Magnavox... | Answered on Jan 06, 2018
If less than a year old, this TV is likely under warranty but should have been taken back immediately to address the issue. I suggest contacting the vendor or manufacturer.
Philips Magnavox... | Answered on Jan 04, 2018
The codes will be the same regardless. Modification of the signals is not possible.
Philips Magnavox... | Answered on Dec 17, 2017
It might be that the sound amplifer is defective if you know anything about electronic you can fix it . If not better take it to someone who can repair it.
The amplifer is the part of electronic that amplifies current so the speekers can be driven. Check it if there is a bad solder or anyhing suspicious.
Philips Magnavox... | Answered on Nov 26, 2017
If its a LCD set not plasma I would look at the connectors going in and out of the Tcon board, remove them and reseat them, if that doesn't help replace the board.
There is one other thing you can try and that is remove the board and put it in your oven at I think its 370 degrees for 10 minutes, Ive never tried doing this but there are some vids on people having good luck doing this, what happens is there are some cold solder joints on the components and putting it in the over will heat them up and the board will work again, search this on youtube and there are vids on how to do it.
Philips Magnavox... | Answered on Nov 11, 2017
Philips Magnavox 27MS343S 27" TV Logo
1,054 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
get replacement picture tubes signature
  • Televison & Video
