20 Most Recent
Philips Magnavox MT1905B 19" TV Questions & Answers
Cannot get the sleep
Good day!
you only have to do is to click again the sleep button on your remote to off the sleep mode timer..
if the problem persist just add a comment to give you a more idea to fix your problem..
your response is much appreciate..
thanks
The red went out in a storm now alot of green.
The red may still be there but no longer seen. The green driver transistor has probably failed that drive the CRT.
A multimeter and a little knowledge will find the shorted part, possibly one of three identical PNs mounted on the small board plugged onto the base of the CRT.
If you decide to DIY, be advised that the CRT can hold voltage for many hours on some sets and deliver a nasty shock.
How to tune the channels
You can tune the channel by Auto programming button in the setting area and then press Auto Scans all available channel option to tune the channel automatically, try it and still facing the problem read the manual carefully for better understanding or you can also call the online customer care available in the manual.
Kindly rate my help++ Thank you
The TV is in what appears to be a showroom mode-
Hi and welcome to FixYa,
On the front panel controls, press and hold the VOL- & VOL+ buttons for 10 seconds or more.
Others with similar concern have tried variations of the above steps as posted by other members
here.
Good luck and thank you for asking FixYa.
I have 2000 tv philips magnavox and I would like
Hi hortense
What you have on the screen is called "closed caption" or CC.
On the original remote look for a button labeled CC or display , then hit that button until it says caption off.
Otherwise you`ll find it in your tv`s menu(closed caption).
If nothing works , let me have the tv`s model number written on the back.
Hope this help, let me know
Can,t unblock channels
Try using the remote, press 3, 1, 9, 7, 5, 3, followed quickly by the mute button. This should bring up the standard menu. and follow the unlock option.
Good Luck!!
Thanks
