20 Most Recent Meade ETX-125PE (500 x 127mm) Telescope Questions & Answers
Either using eyepiece projection and or by using a web cam and or a ccd camera.
http://www.stargazing.net/Astroman/Craters.html
http://www.astronomics.com/main/product.asp/catalog_name/astronomics/category_name/K49JT7XW30VE8G6FWFPL4A3C54/product_id/1321
http://www.astro.shoregalaxy.com/webcam_astro.htm
http://www.meade.com/dsi/
Meade ETX-125PE... | Answered on May 20, 2011
The worm gear in the base may have come loose. You can either return it to Meade for repairs or open up the bottom and try to see what is either loose or broken.
This site can help you:
http://www.weasner.com/etx/menu.html
Meade ETX-125PE... | Answered on Apr 22, 2011
Are you using the internal batteries? Are they fresh and fully charged?
Replace them and try again; or better get a seperate 12 volt power pack and the correct Meade 12 volt cigarette lighter style power cable.
Meade ETX-125PE... | Answered on Feb 28, 2011
This is really TOUGH to dis-assemble. The wiring goes through the central bolt and can be broken easily.
I would suggest that you return it to Meade for repairs:
http://www.meade.com/support/index.html
Meade ETX-125PE... | Answered on Nov 23, 2010
Return it to Meade for repair--
Here:
Meade ETX-125PE... | Answered on Aug 26, 2010
See this web site for pictures of the ETX and repair tips. The best ETX web site on the internet.
Meade ETX-125PE... | Answered on Aug 10, 2010
Give Meade service a call; they sometimes send out small parts free.
Meade ETX-125PE... | Answered on Sep 09, 2009
Here is the Meade manual web site. Find your telescope and see if a part is missing.
http://www.meade.com/manuals/index.html
and here is their customer service phone number:
Meade ETX-125PE... | Answered on Aug 30, 2009
Hi
In response to your email the whole unit is being returned to supplier motor problem is manufacturers electrical fault the meade etx-125pe should have motor limiters fitted which stops the scope slewing more than two revolutions in any direction to stop potential wiring damage this unit does not have them or they are faulty hence motor fault.
Meade ETX-125PE... | Answered on Jan 19, 2009
What are you using as a reference for "LST time"? I assume you're aware
that stands for "Local Sidereal Time", and not Local Standard Time; some
folks have confused the two. Do you have another method to calculate
Sidereal time for your location?
When you set Date and Time in the Setup menu, you need to use the time
from the "clock on the wall" without any mental adjustments for Daylight
Saving or Time Zone; those settings are made elsewhere. From your
description of the problem, it sounds like you have a time offset,
especially if your Site location values are fairly accurate.
Whether you use Zip Code or City sometimes depends on where you live
with respect to a particular city. If you live several miles from the
nearest city, Zip Code may be best .
Meade ETX-125PE... | Answered on Dec 18, 2008
Google (meade)(231)(manual) without parens OR contact Meade directly to request.
Meade Optics | Answered on Aug 24, 2019
Go to: https://www.manualslib.com/manual/525094/Meade-Ds-2000-Series-Autostar-Lnt-Smartfinder.html?page=11#manual
Meade Optics | Answered on Mar 03, 2019
Meade ETX-125PE (500 x 127mm) Telescope Logo
10 questions posted
Top Meade Optics Experts
Gep Pep
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
View Most Popular
Meade Optics
  • Meade Optics
Most Popular Question
etx125 red dot finder arrangement ithe
  • Optics
