20 Most Recent
Philips Magnavox 32PS55S 32" TV Questions & Answers
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.p.s. i am 9
TV 'BLOCK' BOX
the problem is common go into menu and go to text you have to shut it off. each tv is set up a little differant ,
you will have to be patient but im sure that is your answer.
thanks DOCTOR VIDEO
Turn off after one min
Bad flyback you can try adjusting the screen contorl on the flyback this is what goes bad on most of them.
32" Magnavox TV keeps turning off?
youve most likely have a thremal issue that causes the set to **** down when operational temperature is reached possibly a regulator tarnsistor .
Actually, I have an 29PT468A
This should be the 'camcorder' position. It is after Video 2 as you go through the channels.
Regards Clayton.
Adelaide, South Australia.
Philips 32PS55 S321
unless you are a technical electrition its impossible to tell you how to fix it, botom line you will need to take it to a repair store to be fixed , sorry i cant be more helpful
No picture
if you don't have experience on electronic troubleshooting then i doubt that you could fix it.
although it could be simple as to a blown fuse, there are other diagnosis to be done.
i suggest you bring it to a reliable service center/person, have it diagnosed and repaired, if you wish not to mess with it and make greater damage to your tv.
Philips 32" T.V. model 32PT5537G
After some quick checks, it looks like, unfortunately, you have a lemon of a TV. First some basic info. All late model CRT TV's use the high voltage power supply to create all of the voltages it needs to operate. Which saves on parts & costs. The high voltage transformer used in these power supply's can be susceptible to failures & apparently your model is more prone to this than most.
When you said the picture started to distort, what exactly did it look like? If the transformer has not failed then maybe 1 of the power supply filter capacitors is shorted & causing the power supply to shut down. (a safety feature) A local TV repair shop should be able to determine the problem within an hour.
1 thing to try before calling someone, is to see whether the set needs a software reset. Unplug the TV for about 4 hours & then plug it back in. If the problem still exists, then you will need to contact the repair shop.
Geometry settings all wrong
I wish I could help you but you will more than likely have to take your set to an authorized
service center. Philips doesn't like to send service manuals to anyone except their service centers.
Stargazer
