20 Most Recent
Philips 25TR19C 25" TV Questions & Answers
What type of antenna do you reccomend
Lets get started. First the TV you have does not have the new ATSC digital tuner built in. It uses the old NTSC tuner. You might find a few stations, however most major networks have gone Digital because the maximum power for NTSC is limited to 1000 watts. ATSC is the new digital standard for broadcasting both High Definition programs as well as standard definitions programs. So you will need a Digital converter box. They sell them at Radio Shack for around $60. You can get one on ebay for around $25. You will also need and antenna. A good old set of rabbit ears will work fine if you not to far (less than 25 miles) from the transmission towers. If your out in a rural area (greater than 25 miles from the tower) you may want to consider and outdoor antenna. Antennas Direct is a great source for antennas.
http://www.antennasdirect.com/
You can also get help estimating what kind of antenna you need at this web site:
http://www.antennaweb.org/aw/Address.aspx
However you may want to consider buying a new TV which will have a new ATSC tuner built in. You will still need and antenna.
Hope this helps.
Need owners/users manual
owners/users manual comes along with television.you can contact your dealar for that.
if he does not provide you you can contact philips sercice centre located through out world
regards
Standard tv
I have the same problem with a 20" RCA. If I turn on the TV from the unit itself, it goes off in 2 seconds. If I use the remote (universal) it always stays on. Just a solution that works for me. Best,
Rickjsn
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
