20 Most Recent Meade ETX-70 (240 x 70mm) Telescope Questions & Answers
Anyone know where to find a replacement VERTICAL LOCK KNOB for a Meade ETX-70? Or what fix might work instead?
Look at the link below for a FIX for a broken Dec knob. This is a common problem so once it is fixed do NOT overtighten. See this: http://www.schlatter.org/Dad/Astronomy/etx90decknb.htm
8/14/2015 11:25:28 PM • Meade ETX-70... • Answered on Aug 14, 2015
How can i hook pc to telescope
From the AUX port, but you will need Meade software for the PC which comes with a cable. See p25 here www.meade.com/downloads/dl/file/id/.../etx_60at_and_70at_manual.pdf
3/6/2015 5:05:33 AM • Meade ETX-70... • Answered on Mar 06, 2015
0answers
Ext-70 slewing
Be the first to answer 11/23/2013 6:37:21 AM • Meade ETX-70... • Posted on Nov 23, 2013Be the first to answer
I have a Meade ETX-70.
This is usually caused by low battery power-- as the hand controller reported. DO NOT USE rechargeable batteries they do not have enough volts. Use alkaline batteries only.
This can also be caused by a broken gear or a failed internal motor. You can return these to Meade for repair.
Here is the contact number:
http://www.meade.com/support/index.html
9/17/2011 3:42:30 AM • Meade ETX-70... • Answered on Sep 17, 2011
Slew problem
You did tighten the DEC knob? If you did the altitude gears (a worm gear) is not engaing properly. You can either return it to Meade for repairs or attempt them yourself.
I would also check that you have fresh batteries and that the UP button on the hand controller is not broken.
7/31/2011 11:46:38 PM • Meade ETX-70... • Answered on Jul 31, 2011
2answers
A part broke on my
call the manufacturer
7/12/2011 9:14:42 AM • Meade ETX-70... • Answered on Jul 12, 2011
Telescope doesn't get to country/state and has
You can also enter Latitude and longitude in the hand controller as a SITE.
No vertical movement is either a bad hand controller cable, a bad hand controller button, or a broken motor or circuit board inside.
Try a new cable first before you panic.
6/13/2011 3:33:16 PM • Meade ETX-70... • Answered on Jun 13, 2011
Hi, Original focus knob
The knob had a tiny set screw on the side of it-- that tightened down on the shaft.
See if you can tighten it back up. If it is missing take it to a well stocked hard ware store and see if you can find a replacement Allen style set-screw.
4/15/2011 12:16:28 PM • Meade ETX-70... • Answered on Apr 15, 2011
Etx70 AT Will not initilise gives
Only Meade has the boards. Contact them here:
They will probably want you to ship the scope to them for repair.
3/19/2011 7:07:57 PM • Meade ETX-70... • Answered on Mar 19, 2011
The declination knob on my
There are some possible repairs. Go to the Mighty ETX web site and search for DEC KNOB repair.
http://www.weasner.com/etx/menu.html
12/6/2010 5:30:08 PM • Meade ETX-70... • Answered on Dec 06, 2010
The flip mirror is stuck
Go to the Mighty ETX web site and search for disassemble instructions:
10/29/2010 3:28:44 PM • Meade ETX-70... • Answered on Oct 29, 2010
First time using the mead
Did you lock down BOTH clutches?
You should have Calibrated motors and trained drives before you actually tried to do a goto.
Read this manual completely:
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-60-70AT%20manual.pdf
8/21/2010 2:58:03 PM • Meade ETX-70... • Answered on Aug 21, 2010
Need a new vertical lock (number 6 on the parts
Contact Meade customer service:
You might also find one by placing a WANT ad on www.astromart.com
4/25/2010 3:40:15 PM • Meade ETX-70... • Answered on Apr 25, 2010
Need a focus knob for a MEADE ETX-70 TELESCOPE
You can try calling Meade here:
4/16/2010 5:26:30 PM • Meade ETX-70... • Answered on Apr 16, 2010
My son took his meade etx-70 apart can't remember
NEVER take a lens out of an eyepiece or telescope, only clean the outer surfaces.
Try putting the flat sides together and see if that works.
4/16/2010 4:26:32 PM • Meade ETX-70... • Answered on Apr 16, 2010
Telescope tilts up and down without any
You have the famous broken declination knob!! Read these two web sites for the fix. It will require you to disassemble part of the scope.
http://robroy.dyndns.info/astropics/ETX-70/
11/23/2009 1:25:18 AM • Meade ETX-70... • Answered on Nov 23, 2009
2answers
Azimuth motor gearing problem
I also purchased a used Meade ETX-70, only to find it had the same problem with the rotation axis motor running but no movement. After removing the bottom cover, I found the motor w/worm gear would not contact the main rotation gear. I solved the problem but purchasing a small 3/8x3/4x.032 spring that I had to custom fit to hold the motor w/worm gear against the rotation gear. Take caution not to have the spring apply to much pressure or it will cause to much drag.
To gain access, remove the bottom round cover(it will just pop off).
Then use a small .05 allen wrench to remove the set screw in the horizonal chrome lock. The chrome lock fits over a 1/2" bolt. By removing this bolt you will remove the washer/bearing assembly. After removing this, you will see a nylon nut, use a 11/16 socket to remove. Becareful, it is a fine thread and you don't want to cross thread it!
After you remove this, you will be able to remove the bottom housing, which will expose the motor and gear. You should be able to see what I am referring and where to place the spring.
If you can make it this far, then you should be able to install the spring. I used a little small dab of Gorilla glue to hold it in place, since the spring will have enough constant tension to keep it from moving.
I'm not sure if this was a design flaw, but I got no help from the Techs at Meade, only that they would upgrade to a ETX-80 for $149.99 plus shipping.
Hope this helps.......
12/11/2008 1:54:19 AM • Meade ETX-70... • Answered on Dec 11, 2008
Meade ETX-70 (240 x 70mm) Telescope Logo
22 questions posted
Top Meade Optics Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Meade Optic Expert? Answer questions, earn points and help others
View Most Popular
Meade Optics
  • Meade Optics
Most Popular Question
need new vertical lock number 6 parts
  • Optics
