20 Most Recent Philips FTR-9964 Tuner/Receiver for Plasma Questions & Answers
Green light flashes 3 times philips tv
change power supply
5/2/2016 2:37:38 AM • Philips FTR-9964... • Answered on May 02, 2016
2answers
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
7/2/2013 7:31:09 PM • Philips FTR-9964... • Answered on Jul 02, 2013
0answers
8answers
Philips plasma tv model#42PF7320A/37
have 3" black line in the middle of picture
8/25/2010 9:46:46 PM • Philips FTR-9964... • Answered on Aug 25, 2010
No tv channels with Philips 42FD9935/17
If you are using a Cable Box, then select the Cable Box option in the TV. If you have connected the Antenna directly to the TV, then select the Antenna option in the TV under Menu options. Try performing the Auto program.......If using a Cable Box, then no need to perform the Auto program. If the issue persists, try resetting the TV to the factory settings and check if it helps.
7/26/2010 2:58:43 PM • Philips FTR-9964... • Answered on Jul 26, 2010
With all this Philips plasma
yes, Sony has a very good quality. Sony has been in market over the years and they are known to produce quality products.
Also, electronics in generally are not to be trusted. It can develop fault at any given point in time. This might be as a result of irregular power supply or factory error.
But Sony is good electronic product. One also has to be careful, so that the fake one won't be bought.
I agree with you that Sony has a very good quality and that true.
Take care.
4/16/2010 1:06:43 PM • Philips FTR-9964... • Answered on Apr 16, 2010
2answers
Seing ghost pictures but when the box got hit of
This could be a problem with the leads connecting the box to the tv. try using different leads and see if that cures it
11/26/2009 9:59:49 AM • Philips FTR-9964... • Answered on Nov 26, 2009
Tv wont power on. red light keeps blinking
line not working will prob be a voltage regulater transister
9/7/2009 6:37:00 PM • Philips FTR-9964... • Answered on Sep 07, 2009
Cannot swtich on the tv
I think you mean ' switch ' and ' only the red light ' ( power ) comes on.
It could be an internal trip on your tv set that needs looking at by a tv engineer ( normally parts required ) or if you have a tv with a ' factory settings button ' on it ( normally on the side or top if it's a flat screen tv ) press and hold for 10 seconds then the intial ' tv setup ' will appear on the screen ; after that, just follow the guide.
Hope this helps.
7/24/2009 10:59:16 AM • Philips FTR-9964... • Answered on Jul 24, 2009
power card defective
7/6/2009 9:32:19 AM • Philips FTR-9964... • Answered on Jul 06, 2009
Philips FTR 9964 tries to switch on but light above power switch
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
6/25/2009 3:11:20 PM • Philips FTR-9964... • Answered on Jun 25, 2009
Philips FTR 9964 tries to switch on but light above power switch flashes red
6/19/2009 12:59:07 PM • Philips FTR-9964... • Answered on Jun 19, 2009
2answers
Menu
I download new software from internet and insert to TV and it works.
3/13/2009 5:42:23 PM • Philips FTR-9964... • Answered on Mar 13, 2009
2answers
Ftr9964
xcbsfbsf?
1/18/2009 6:17:51 PM • Philips FTR-9964... • Answered on Jan 18, 2009
The reciever box light flashes red
Same issue here in NZ with a set.  Fixed (twice) before.  Same problem for the thirs time in 4 years. Solution  - get a Sony.
12/26/2008 9:50:56 AM • Philips FTR-9964... • Answered on Dec 26, 2008
Philips plasma tv model #42pw996217
Kevin I don"t know if you still have this problem? but if so I have a box and a remote. make a good offer and its yours.
R.Carter
469-337-4962
[email protected]
11/11/2008 3:09:51 AM • Philips FTR-9964... • Answered on Nov 11, 2008
Televison & Video Logo
33 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
cannot swtich tv
  • Televison & Video
