20 Most Recent
Webroot Spy Sweeper 3 (667208652105) for PC Questions & Answers
Spy Sweeper purchased in July, 2009 will not work with Windows 7.
Ms Mason,
With Windows 7 there comes an improved Compatibility feature which allows you to run programs apparently not functional in Windows 7. In order to do this, please install the program as usual, making sure to tell the installation program to install a desktop icon. When it is finished, right click on the icon and select properties. The next window has a tab called compatibility. Click this tab and select Run program in... and select Windows Vista or Windows XP SP3 (either should work). I would also set it to run as administrator. See graphic below.
If the program wont install at all, than explore the CD and do the same process with the "setup.exe" program on the CD.
Good Luck,
NOLA Tech
I need driver update for my Webroot Spy Sweeper
The driver isn't the problem, your version of the Webroot is - it's incompatible to Win 7.
Get the new version http://www.webroot.com/En_US/consumer-products-antivirus.html?WRSID=3d790ba983c5fccf5b52599947ae46cb
I deleted my webroot anywhere by mistake and i would like to get it back.
I suggest you contact Webroot support supplying your registration. Although it is often difficult to entirely remove Webroot without using special tools from the Webroot site, I am uncertain what might remain of the prior installation and indeed any installation file and installation key. I would have at my disposal and email confirmation you received when installing the product. Use your email search capability. I take it you currently are without antiviral protection and suggest you limit your use until you get your installation back. Of course, you could install something else until then but then that would have to be disabled and removed before you reinstalled Webroot. You might opt to call them on the phone. I don't know if your version is one provided via Spectrum cable services or not but if it is, that might be another route to reinstallation.
https://www.webroot.com/us/en/support
8/29/2022 6:57:59 AM •
Webroot...
Answered
on Aug 29, 2022
Is webroot installed on my computer
Webroot is an antivirus program that you have to purchase. To check and see if it is present, click on the search bar and type webroot or type programs and features and see if it is listed on the add remove program section.. PS you don't need it. if you have windows defender.
1/9/2020 11:24:44 AM •
Webroot...
Answered
on Jan 09, 2020
Child Safe will not accept my CS Control Password
Hello there
First things first:
1) Uninstall the webroot sofware
2) restart your computer
3) depending on your OS, if win 7 , 8, 10
you have to system restore point from the day before you install webroot.
4) restore and restart, problem solve!
Carl
4/25/2017 8:51:44 PM •
Webroot...
Answered
on Apr 25, 2017
Error netflix
Yes. Go to settings on your Webroot console or dashboard and find the firewall settings. From there make an exception for Silverlight so that it will be allowed through.
2/5/2015 9:15:00 AM •
Webroot...
Answered
on Feb 05, 2015
