20 Most Recent
Philips DVD625 DVD Player Questions & Answers
Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup.
[from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
Unlock region code for Philips DVDR3480 region
Here you go.....
The only thing you do to unlock DVDR3480 is this:
With NO disc in your DVDR3480-player you press SETUP on the remote and then press this code: 5 0 1 8 ,now you can pick Region-code with the remote from 0-6
( 0=Region free)
Karlos
What is the cost of lens of philips 625k dvd
TO my knowledge, the optics assembly is not available. The replaceable part is the entire DVD mechanism. If you can update this with the exact model number, I can confirm that and provide the part numbers and costs.
Thanks,
Dan
Region free codes dvp 3688
The above codes do not work on the DVP3688 but the one for the DVP3600 works on the 88 model, I just did it this morning.
1) Go to settings
2) scroll down to preferences and make sure one of the option is highlighted in that menu (any options will do)
3) then press the keys "next, previous, next, previous" on the remote, they are the little arrow keys you normally use to skip a scene while a DVD is playing.
4) after pressing that key sequence, your current region is displayed, use the arrows on the grey circle key to find region 0 and press OK
voila, DVP3688 is now region free.
How do I region free
turn on player without disc. push home button(looks like a house) on remote. enter 1389310 using remote. wait 10 sec then turn off at front of player. wait 10 sec then turn on at front of player. thats it
When we start our DVD
Hi yogeshsghige ,
The default password could be 0000 or 12345 or something else , and it should be mentioned in your player's manual , do check the manual and find out the default password.
Hope this helps ..:)
Cant get the disc lock
Is it asking for a 5 digit passcode? Try 136900. If that is successful, then using the remote, go to the menu and chose the Disc Unlock option.
Hope this helps!!
If we insert disc it
Please try others disc. If still the same , clean your lens with cd cleaner. If problem persist, replace your lens
