20 Most Recent
Philips HDD120 MP3 Player Questions & Answers
Hdd120 on Vista
I'm a bit late to the party here but the solution is to right click the shortcut to the Philips DMM and run as an Administrator. It all works fine if you do.
I have a Philips Jukebox
According to Philips:
The player does not support Windows 7.
It is because the player was designed before the release of newer technologies such as Windows 7. Given the technological design, a driver for making the player to support Window 7 is not possible.
The player supports Windows 2000, XP and Vista.
Usb device not recognized
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU!
Mp3s
Try downloading updated software from philips.co.uk.You may need to specify what pc operating system you are using.ie windows xp, 98, 2000 etc
Philips hdd120
Install and run the DMM software from the product CD.
Repair the player using the DMM software.
I
Phillips HDD120/05
Repair the GoGear - warning: this will delete all files from your player.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
-Tha Mp3 Doctor
Phillips hdd120 will not charge
i think battery is disconected inside unit, or battery is very dead. open up unit and look / test battery for life. or replacebattery
Wont turn on
hiya!! i have one of these pesky things. it has a mind of its own!! u need to reset it by pressing "previous track" and "volume up" buttons (in that order). screen should go blank, then turn on as normal. also i would recommend updating firmware to version 6.6 at www. phillips support
