20 Most Recent
Haier HTF27R11 27" TV Questions & Answers
I beleve there are three settings personal,video,game..
Without the remote, some TV's are useless. Is there a menu button on the TV itself? If so, you will have to determine what buttons do what. For example, volume up and down may let you scroll through the menu while channel up and down may let you go left or right in the menu. If you only have volume, chanel and input/source buttons, you may need to order a new remote to solve this.
Blue screen and red padlock
It sounds to me like a child lock function, which is usually what the screen + padlock is on TVs. Usually your original remote would have a button / sequence to unlock the mode. If you still have your original remote, look for a child lock button or refer to your remote manual (and/or TV manual for the child lock feature) to unlock the mode.
Zoom
I have exactly the same problem! PLEASE HELP ME!!
Blue screen red padlock
what is the problem.
is your remote is not working or you have only blue screen.
hope you will clear it.
Modo servicio tv haier
To know more about how to enter service mode to this TV, check this link.
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and
press '
Enter' or view it in
Mosaic / Timeslide
option.
Arcing in back of tv
Check and replace the final anode cap. It is leaking. If you wish to get more details, check this site.
Products powered by electricity
should be serviced or repaired only by experienced professional technicians.
Any attempt to service or repair the product by anyone else could result in
serious injury or death. If
you are not familiar with electronics, do not attempt to repair.
Whether you suffer fatal electrical shock. Instead, contact
the nearest service centre.
type in the
box, and press '
Mosaic / Timeslide option.
My haier tv is stuck on 3.0. it wont do anything
Just try a hard reset first. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. It must make it a hard reset. If it do not help you, replace its main system control memory IC. It will look somewhat like this, and will have 8 solder terminals.
Codigo del control remoto polar para haier tv
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to
many popular brand remote controls are given.
Three digit, four digit, five digits and two-digit code list are
there. Check the site with
patience. Surely you'll get a solution
to your problem. Search the site by
'Timeslide' option. It will make search
easy. Or, type in the brand name to
your device into its search box, and press "Enter"
No pitcure out
If power supply is OK, and standby light is ON when you power ON the set, the main digital board is likely to be faulty.
Some channels are blocked due
Some tvs could do reset the setting,by unplug,replug it back like 24 hours later.This is a hard reset no power tv power source,will reset everythings in most tvs.
