Vulcan double deep Fryer with built-in filter system model 2GR45AF the pilot light is lit, but the burner don't fire and heat the shortening
HI.
Its Bob
To fire up, you need 3 things,
Air ( with oxy) fuel and source.
First step, is to make shure, you have gas.
Without this, you will never get no were.
Second , you must purge the system to get air out of the gas line.
this is done by trying to light up the system , 4 to 8 times,
here the click is the valve opening and closing....
this will clear the system out of air and get the gas to the burder.
this will take time, 4 to 8 tries...
if you smell for any reason gas, stop, shut off the gas...
This smells like rothen eggs...
Gas is heavier then air, so it flows down to the lowest level.
there is also sensors ,switchs on this...
Read the instruction on how to purge or turn on the gas...
some have to push down hold for 5 secs, then turn..
Please work safe/
bob
