20 Most Recent
Emerson SB350 13 in. TV/DVD Combo Questions & Answers
Is there a specific solid state part known to make the fuse blow in model number sb350
It sounds that there is some short circuit with its main power supply regulator circuit. A detailed check is necessary to locate the exact faulty component/s. If you are sound in electronics, you can do it by yourself. If not, contact any service technician. If
you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over
2350 posts now. All are related to
electronic equipment repair help. If
you check the site in Timeslide option, which can be selected from the drop down
list at the top left side of the display window, it will make search easy.
Tuner
the answer is yes. Once you get another tuner, simply use soldering iron to remove the old turner from the TV panel board and replace with another.
Good luck.
Emerson sb350 ( spongebob dvd combo )
I had the same problem.I fixed it by unpluging the tv.Then while holding in the power button I plugged it back in,still holding in the power button for twenty seconds.That fixed it.I read somewhere you could reset a Sony that way so I gave it a try and it worked.I also put a cd cleaning disk in it because it was saying "wrong disk" and that fixed that problem.Good Luck
Dvd problems
i'm getting the same problem. it worked 3 days ago and now all it does is just spin. I have even tried a brand new dvd. I've had mine for about 5 mos.
How to setup a onn remote control to a emerson TV
1. Turn on your Emerson TV.
2. Consult the ONN remote manual for Emerson TV codes.
3. Press TV on the ONN remote.
4. Enter the correct code.
5. Test remote functions.
- If unsuccessful, try code search or auto-programming.
6. Ensure compatibility.
1/8/2024 3:58:07 PM •
Emerson...
Answered
on Jan 08, 2024
My Emerson DVD player says Disc Error Playback feature may not be available on this disc
The error message "Disc Error Playback feature may not be available on this disc" can have a few different causes. Here are some of the most common:
- The disc is not compatible with the DVD player. Some DVD players are only compatible with certain regions or formats of discs. If the disc you are trying to play is not compatible with your DVD player, you will get this error message.
- The disc is damaged. If the disc is scratched, dirty, or otherwise damaged, it may not be able to be read by the DVD player.
- The DVD player is faulty. If the DVD player is faulty, it may not be able to read discs correctly.
Here are some things you can try to fix the problem:
- Try playing the disc in another DVD player. If the disc plays in another DVD player, then the problem is with your DVD player.
- Clean the disc. Use a soft, dry cloth to clean the disc. Be careful not to scratch the disc.
- Format the disc. If the disc is formatted for a different region or format, you may need to format it for your DVD player.
- Reset the DVD player. If the DVD player is faulty, you may need to reset it.
If you have tried all of these things and you are still getting the error message, then you may need to replace the DVD player.
7/6/2023 7:52:52 PM •
Emerson...
Answered
on Jul 06, 2023
