20 Most Recent
Emerson EWC20D3 20 in. TV/DVD Combo Questions & Answers
TV shows only about a one inch wide horizontal
In the old days that meant that your "flyback transformer" went bad and needed to be replaced.
Now a days it might be cheaper to just buy a new TV set - especially if it's over ten years old. Give it to Goodwill and see if one of their workers can fix it for resale to lower income folks..
I have a EWC20D3 Combo that does not respond to remote.
Check the remote control for its infrared emission first. Check it with fresh batteries. If
you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over
2350 posts now. All are related to
electronic equipment repair help. If
you check the site in Timeslide option, which can be selected from the dropdown
list at the top left side of the display window, it will make search easy. Detailed description about how to check and repair a remote control is given in detail by one among the posts.
Emerson EWC20D3 20 in. TV/DVD Combo what is that loud whining noise from the back
What happens in this case is a small transformer or the high voltage transformer vibrate hard enough to make that sound--not loose or bad but can cause the vibration.I have seen in customer's homes where it was loud enough to chase cats right out of the room even in a large room.Two ways to deal with this----with the set apart locate the part by ear or even probing with a plastic tool---when you press close to it, the sound will diminish or go away.Believe it or not (in our shop) once located we use a hot glue gun to take the sound away---usually if very loud it is the high voltage transformer on the main TV board (see photo of a typical one) not on the black part but on the iron like (it is a different material) core that looks like a U bolt.it can irritate but poses no danger.
I no longer have the
you will not be able to do all you want with out remote on these types of units
you should just call or write to Emerson and get a replacement from them
it will be easier than the headaches you will have trying to get a replacement that will do all the functions the original did because none of them do
good luck
I recently lost my remote
This problem can't solved without the remote.Because the remote the only one have a SAP button on it.Try website like Remotes.com to buy an exact remote to the original remote.
What is the weight of this tv?
Hello
The specifications are
Power consumption
(Maximum) : 85W
Dimensions : H:20-3/16"(513.5mm)
W:20-3/16"(512mm)
D:19-13/16"(503mm)
Weight : 49.6lbs(22.5kg)
OK.
I need an mannual to operate my tv
Just copy and paste this link into your internet address bar in a new tab and it will take you to the user manual site:
http://www.devicemanuals.com/guide/Television/Emerson/Emerson-EWC20D3-20-TV-DVD-User-Guide-TmpJeE5ETT.html
V chip on and remote is gone
no. you are a child that wants to watch bad shows huh? well you are on the internet so do it here.
by the way, the "v chip" is just a basic programming in the computer so you cant actually take a chip out.
