20 Most Recent
Emerson EWC1903 19 in. TV/VCR Combo Questions & Answers
Every time i put a
Sounds like your vhs take up wheel is not doing its job. Vhs unit needs repair or replacement.
Can you tell me the
try this:
004
009
014
023 024 025 026 027
030 032 033 034 035
036 037 038 039 040
or this:
11864
No sound,volume bar works
Sorry I dont have a manual but it is available at http://www.servicemanuals.net If you put your ear close to the speaker, with the volume turned up, do you hear any hiss or buzzing? If you dont it could be a bad speaker,headphone jack(if there is one), or the audio output IC or ascoiatated componets. If there is a hiss, then theres a problem with the audio processor or switching IC. If your not a tech, you should not be experimenenting around inside this TV set!
Tv off by itself.
Oye tu problema es que el sistema de la vcr esta fuera de tiempo,trata cambiandole la banda de el motor de carga ya que si esta se encuentra desgastada patina y haceque el micro detecte error y por eso se apaga el televisor.Suerte.
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Tv wont turn on
The sound can be called screaming from the power supply,it senses a short and creates a frequency you can hear,the set has a problem and it needs to be repaired,I will check the horizontal out put transistor for a short,sometimes it goes bad without a reason and sometimes the high voltage transformer is also bad and both have to be replaced but first the transistor only if it goes bad again then you replaced the transformer too.Seek assistance from a servicer if you are not too familiar with tv service,it can be dangerous.
Sounds like it may be something you did. Have you checked to see if you accidentally put the sound on mute? Try hitting the mute button on the remote control. Also, if the TV has the option to turn of internal speakers (which you would likely find in the menu under audio settings if it does) make sure they are turned on. If these checks fail then we have an electronic problem to deal with.
How to setup a onn remote control to a emerson TV
1. Turn on your Emerson TV.
2. Consult the ONN remote manual for Emerson TV codes.
3. Press TV on the ONN remote.
4. Enter the correct code.
5. Test remote functions.
- If unsuccessful, try code search or auto-programming.
6. Ensure compatibility.
1/8/2024 3:58:07 PM •
Emerson...
Answered
on Jan 08, 2024
