20 Most Recent
Fuji FinePix A340 Digital Camera Questions & Answers
Deleted photo recovery
This
camera photo recovery tool is maybe what you are looking for.
Remember - DO NOT write anything back to your digital camera untill you recover the photos safely. Once the photos are overwritten, it is impossible to recover. Best regards.
Card error message
Without knowing the error I can not help you. I would recommend investing a new camera, or buying one used from amazon.com for $5.
FINEPIX a340 to windows 7
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or
Picasa.
My computer has Windows Vista. When I run the CD
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Windows Photo Gallery or
Picasa.
I just received a A340 and do not know how to use
The manual for this camera is available to down load from the Fujifilm uk website. Just click on "service and support" on their home page and select your camera from the drop down menu near the top of the page.
Usb leads are readily available from ebay
I do not have the cd where can i find it?
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
How to initialize card
Press the MENU/OK button. Use cursor-left/right to select "SET" then use cursor-up/down to select "Set-Up" and press MENU/OK. Use cursor-up/down to select "FORMAT".
