20 Most Recent Fuji FinePix A303 Digital Camera Questions & Answers
In photo mode (not in view mode) there is a 'format' function under 'Menu'. This erases everything on the memory card, so transfer the pictures you want to keep to a safe location first.
A download link for the manual of your camera is provided below.
Fuji FinePix... | Answered on Jan 27, 2016
Transfer images to computer or delete unwanted images
Fuji FinePix... | Answered on Sep 30, 2015
put it in camera usually they just do their thing I have never had to format one for my cameras
Fuji FinePix... | Answered on Sep 13, 2015
All your pictures are saved on the memory card of your digital camera automatically.So you can recover your deleted pictures from memory card with third party data recovery software.I have a professional program on my computer that can recover data after deeply scanning your memory card to look for lost data you accidentally deleted or formatted. By the way,you can download it and scan your memory card for free to preview whether your erased pictures can be recovered. Get it from http://www.any-data-recovery.com
Fuji FinePix... | Answered on May 05, 2014
check if in the card slot is any debris. You could try to clean the contacts of the xD memory card with a dry cloth. Place the card on a flat underground and press firmly on the cloth. Don't press without a flat underground, because you could easy break the card.
It also could be some of your pictures are protected. You have to unprotect the pictures first.
Fuji FinePix... | Answered on Nov 15, 2013
I had the same problem with a Fufifilm camera. When I looked closely at the memory card I noticed a little white sliding button on the left hand side. When it is in the down position the card is locked or protected. Just slide the button up and put it back in your camera and it should work.
Fuji FinePix... | Answered on Dec 07, 2012
Press the MENU/OK button to bring up the menu. Press cursor-left to move to the tabs. Use cursor-up/down to select the SET tab (wrench icon). Press cursor-right to enter the setup menu. Use cursor-up/down to select the item with two Chinese characters, a slash, and "LANG" (speech-bubble icon).
Fuji FinePix... | Answered on Aug 09, 2011
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Fuji FinePix... | Answered on May 02, 2011
Here is a tip that I wrote about how to find the manuals, drivers, downloads and support for Digital Cameras.
Digital Camera Manuals, Drivers, Downloads, and Support
heatman101
Fuji FinePix... | Answered on Apr 23, 2011
This camera was made at a time before everyone had standardised on "SD card". You will have to search a little to find a suitable card, because the format is now obselete.
The format you need is called xD-Picture Card and you can find a description here.
Fuji FinePix... | Answered on Jan 19, 2011
1st replace it with new batteries. if the zoom lens is coming out and going in after putting on and off.if not then dust is the problem. while putting it on try to pull the lens slightly or if it out then try to press in slightly if doesnt work then replace lens unit
Fuji FinePix... | Answered on May 28, 2010
change my camera language plz
Fuji FinePix... | Answered on Mar 29, 2010
Please read above. I think the problem will be solved with instructions explained in figure.
Fuji FinePix... | Answered on Mar 06, 2010
do you have a sound cards in your camera where you can take out the card and put it into a computer. try this buy a card reader and put the card into the reader and hook it up to the mac, (which I have ) and maybe they will show up. you have a program on the mac called i photo and thats how i do my pics, but if it doesnt show then yes u prob lost them but try this. it may work good luck.
Fuji FinePix... | Answered on Nov 28, 2009
I guess you got a serious problem with your camera. The camera you have a problem that I said bad induction in the motherboard camera. The solutio, you have to replace your maiboard with the new one. So, bring your camera to the service center.
Fuji FinePix... | Answered on Oct 25, 2009
Calm. The deleted image can be obtained again, as long as memory is not broken. It can use recovery software, like recover my file or any other the similar.
Fuji FinePix A303 Digital Camera Logo
56 questions posted
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
fujifilm finepix f40fd protected card
  • Cameras
