20 Most Recent Fuji FinePix 2800 Zoom Digital Camera Questions & Answers
armanhotarman
Fuji FinePix... | Answered on Aug 01, 2017
how to transfer pictures to pc
Fuji FinePix... | Answered on Nov 21, 2014
You may download a copy of the manual at http://www.fujifilmusa.com/shared/bin/FX-2800_Manual
Fuji FinePix... | Answered on Aug 31, 2013
did you connect the camera to the computer via teh cable supplied with the camers. this should resolve the problem.
Fuji FinePix... | Answered on Aug 09, 2012
Check for a burn bulb.
Fuji FinePix... | Answered on Jun 18, 2012
If you mean that your camera won't format the card, make sure you're using a card the camera can use. For example, if your camera can only use SD cards, then it won't work with an SDHC card.
Fuji FinePix... | Answered on Nov 13, 2011
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Fuji FinePix... | Answered on Oct 10, 2011
Its possible that you need reinstall your drivers camera or download from Fuji site some firmware update.
Keep us updated.
Fuji FinePix... | Answered on Sep 21, 2011
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and SupportHow to easilydownload Pictures from Digital Camera
heatman101
Fuji FinePix... | Answered on Aug 24, 2011
Diana..,
I located the usb driver you need to make the connection with the computer . on this location you will find the driver for windows Xp ...cause I do not located for vista .. if you use other operating system let me know and I will see what I can do ...( I do located for Mac too all but vista )
http://www.mediafire.com/file/qzz2gljmgiz/fuji finepix driver xp.exe
have a great day ..and Enjoy!
Here is a tip that I wrote about How to get a Digital Camera Lens to work again
Steps to Repair a Digital Camera Lens
heatman101
Fuji FinePix... | Answered on May 14, 2011
Wow, these cameras work the best with rechargeable type batteries the Alkaline batteries will just die before you get 50 pictures. If you are using the LCD screen all the time it's a power hungry hog and will kill the best of batteries quickly.
You should program the camera to auto shut off in 2 minutes, review time should be about 1 minute and the camera should be in sleep mode or turned off between pictures to conserve as much power as possible.
I use a Fuji S100fs camera a lot for a walk about, documentary, time laps and generally shooting and can get about an hour of continues use from one battery and about 190 frames.
Fuji FinePix... | Answered on Apr 19, 2011
Consider NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Fuji FinePix... | Answered on Apr 08, 2011
i experienced same problem and solved by resetting all settings to default by going in set up menu.
Fuji FinePix... | Answered on Mar 18, 2011
Due to its age. It is not compatible with Vista. However you should be able take the memory card out and use a card reader instead to connect that to your computer.
Fuji FinePix... | Answered on Feb 28, 2011
Fuji FinePix 2800 Zoom Digital Camera Logo
Popular Tags
93 questions posted
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
need user guide
  • Cameras
