20 Most Recent Fuji FinePix A310 Digital Camera Questions & Answers
Sir i have new camra but i donot know how to turn it on and off and also which type of cell are use in finepix A310 i use normal dry cell which are not charege able
All the information you require should be in the manual. If you did not get a manual with it, return it to the store and ask for one.
6/2/2016 11:31:23 AM • Fuji FinePix... • Answered on Jun 02, 2016
0answers
Camera shuts down
Usually when the batteries are low a camera will shut down right after it is turned on. Try changing the batteries and see if this helps the problem.
5/2/2011 11:05:30 PM • Fuji FinePix... • Answered on May 02, 2011
Focus error (can't take pictures) A310 Fujifilm
A couple of quick things come to mind first is you may be way to close to your subject for the camera to focus OR you are trying to take a pictures of a shiny subject, painted wall a mirror or some other subject that lacks contrast
12/26/2010 4:24:14 PM • Fuji FinePix... • Answered on Dec 26, 2010
3answers
Fuji finepix a310 won't take pictures
we have the same problem too.
8/23/2010 9:35:00 PM • Fuji FinePix... • Answered on Aug 23, 2010
Okay i lost a part of my charger, and the battery
Please try below link
Fujifilm Finepix
7/25/2010 7:36:07 AM • Fuji FinePix... • Answered on Jul 25, 2010
Heya guys im wondering if uu caould help me out,
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
6/8/2010 10:32:39 PM • Fuji FinePix... • Answered on Jun 08, 2010
The camera has started giving me a redish display.
image formation is defective,C.C.D. failed ,replce with a new one.
2/28/2010 8:54:47 AM • Fuji FinePix... • Answered on Feb 28, 2010
Image purple in viewer. Photo reproduction green on screen.
Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
9/22/2009 10:26:40 PM • Fuji FinePix... • Answered on Sep 22, 2009
2answers
Locking up, no image in display
Have you tried pressing the DISP buttons? How about if you just browse through the pictures, does the LCD turn on? IF not, you have to have it checked or replaced...
9/19/2009 8:15:40 AM • Fuji FinePix... • Answered on Sep 19, 2009
Dodgy colours, mostly green and purple, horizontal lines
finally!!!! i found somebody with the same problem!!! my camera does the same thing. i havent used it in years and now it does that.
please, please, please, please contact me if you find a solution or something close to a solution.
[email protected]
mason
7/12/2009 6:28:58 PM • Fuji FinePix... • Answered on Jul 12, 2009
Language setup
In viewing mode, not camera mode
1. Turn the mode wheel until you the see the green arrow(just above the movie mode)
2, Turn on the camera
3. press "menu/OK"
4. There are four tabs, goto "SET(option)"
5. push up to "SETUP" and hit "OK"
6. Push down 8 times
7. Push right until it says "ENGLISH"
Hope this helps
5/18/2009 12:33:09 AM • Fuji FinePix... • Answered on May 18, 2009
Fujifilm Finepix A310, unable to capture photos
Sir, You have used the camera since 2004 upto 2008. Now, you know that 4 year is enough time for a digital camera to run. The only solution is to throw it to dustbin & buy a new one. Otherwise, you may spend money in vain with your existing camera. Why?
2/24/2009 5:19:49 PM • Fuji FinePix... • Answered on Feb 24, 2009
My camera will not work with regular batteries
as far as it is working with re chargeable's then it is ok what is wrong with it , it needs more power i mean MAH so give it , to sell it go to ebay check the similar model price how much ppl are selling and post ur product
2/20/2009 9:25:42 AM • Fuji FinePix... • Answered on Feb 20, 2009
FOCUS ERROR A310
it would happen because the alignment of the lenses has disoedered
1/7/2009 2:06:39 PM • Fuji FinePix... • Answered on Jan 07, 2009
Fuji FinePix A310 Digital Camera Problem
I bet you're using he maximum pic resolution on the camera, and the problem you mention isn't really a problem but a limitation of the camer itself. The delay you're seeing is the time it takes for the camera to "write" the picture to the memory card. It something I've seen in most of the FinePix cameras and the only soltuion is to reduce the resolution of the pictures, thereby reducing the size of the "write" to the card. Sorry if this isn't the answer you're looking for, if the answer is acurrate, I would appreciate a rating. Give the resoltion change a try and let me know if the write time is faster.
10/23/2008 10:12:09 AM • Fuji FinePix... • Answered on Oct 23, 2008
3answers
Finepix A310
It could be the CCD, fuji has admited a few of their models have the faulty CCDs and there is a list of serial numbers you can look and see if yours is in the list. You may want to call them and see what they say. Ide try and call a few different times if they say it isnt, try again later and see if you can talk to a different opperator. Some may or may not know so dont just take the first pesons word for it if they say no. If you bang on the side of the cammera does it work ok again? usualy if its the CCD problem a bang on the side of the camera fairly hard is enough of a shock to cause it to work again.
9/6/2008 11:01:31 AM • Fuji FinePix... • Answered on Sep 06, 2008
5answers
''focus error''
Check out this link: www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
After the basics (cleaning the lens, replacing the batteries, etc.), try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working. Dropping the camera loosens the debris and voila!
9/6/2008 10:45:16 AM • Fuji FinePix... • Answered on Sep 06, 2008
Pink screen on A 310 Fuji camera
This is a CCD problem It may be subject to a recall Contact Fuji Technical Support
9/6/2008 10:44:09 AM • Fuji FinePix... • Answered on Sep 06, 2008
Fuji FinePix A310 Digital Camera Logo
37 questions posted
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
sir new camra but donot know turn off
  • Cameras
