20 Most Recent Fuji FinePix F401 Digital Camera Questions & Answers
Dont purchase cameras with japanese language in future if they dont provide translation in english..
Fuji FinePix... | Answered on May 06, 2017
Need model number before I could figure out.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christpher_f760d0f18f8eedc3
Fuji FinePix... | Answered on May 15, 2014
At the bottom of your Facebook page, click the link next to the 2014 Facebook copyright, then select your flavor/flavour of English.
Fuji FinePix... | Answered on May 11, 2014
Try doing so by getting into BIOS Settings. If it doesn't help, contact your Laptop Manufacturer's Customer Care.
Fuji FinePix... | Answered on Mar 29, 2014
Ok did the lens open completely? Does the lens cover open. I have had a Panasonic do this once. If it opens the sensor most likely is gone, or the display. Sometimes if you are careful you can remove the back an check the connections to the screen by removing it an putting back on an it can clear the problem. Sounds crazy bit has worked a few times on other cameras. My guess is camera is gone an cheaper to replace.
Fuji FinePix... | Answered on Mar 24, 2014
Download the manual:
http://www.fujifilm.co.uk/media/dContent/mediaCentre/Manuals/f401manual.pdf
Here you see how the menu works, and you can change the language.
Fuji FinePix... | Answered on May 06, 2013
I HAVE FUJIFILM CAMRA BUT WARE IS THE LANGUAGE CHANGE OPTION PLZ TELLL............
Fuji FinePix... | Answered on Oct 23, 2012
The manual is at
Here you see how the menu pattern looks, and you can follow the visual cues to change the language to English. The menu layout is the same in every language.
from the above symptom , it indicate that your lens module is faulty,you need to replace the lens module.hope it help.
Fuji FinePix... | Answered on Aug 30, 2012
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Fuji FinePix... | Answered on May 26, 2011
Hi majidsabir,
It is very difficult to navigate you on how to navigate in changing the language. However, I have a copy of the manual for your camera. Please open it and check Pages 78 - 79 on how to change the language. It includes pictures to guide you as well. Click HERE the Manual
Hope this helps.
Fuji FinePix... | Answered on Feb 22, 2011
Here is a link to the camera's full manual, there are instructions there for all functions.
http://fujifilm.co.uk/media/dContent/mediaCentre/Manuals/f401manual.pdf
It would be best to print the manual as it makes it easier to look at it at a later time.
Good luck.
Fuji FinePix... | Answered on Jan 28, 2011
Fuji FinePix F401 Digital Camera Logo
65 questions posted
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
want change language
  • Cameras
