20 Most Recent
Fuji FinePix A101 Digital Camera Questions & Answers
Still pics
Try removing the batteries and re-install to reboot the chip.
If still same problem more than likely an internal part has failed.
Most cameras cost more to fix than they are worth. Suggest in that case to upgrade to a newer model.
Lens problem
You might as well replace the camera in this case.
I had 245 pics stored i went into format mode by
dont shoot anything on card
just take out the card are they on card or camera if on camera then just connect ur camera to pc or if card just insert card on card reader or connect camera along with card and try this software of recovery
http://www.recuva.com/update/?v=1.21.373&l=1033
and try to recover ur files thru conneccting camera normally and selecting the rem drive that appears when u connect ur camera in options and then scan the camera or card see if it recovers ur pics
The power supply get drops
Hi and welcome to FixYa,
A few ideas that you can consider/try:
- make sure the batteries are fresh/fully charged;
- clean the battery terminals of the camera;
- in some instances, it may be needed that these terminals be scrapped/scratched to remove corrosion/oxidation and expose fresh metal;
- at times, it may even require that these contacts be stretched/bended so as they offer stronger pressure to the batteries.
Good luck and thank you for using FixYa.
Focus error finepix hs10
About the HS10 autofocus problem, I discovered the cause and solution. It is a problem of camera design, and is caused by three screws securing the CCD sensor. These screws are not properly secured and the vibration eventually dropping.
In two cameras with the same defect, the screws were loose. These screws adjust the sensor position relative to the lens and the sensor is loose when out of position not allowing proper focus.
The solution is to disassemble the camera and secure the screws.
These screws can not be too tight they need to be adjusted to position the CCD sensor correctly. The camera is difficult to dismantle because several wires are soldered.
Care must be taken to discharge the capacitor of the flash, this may cause an electric shock and burn the camera board.
Those who want to try the repair, follow the link to the service manual.
http://elektrotanya.com/fujifilm_finepix_hs10_hs11_sm.pdf/download.html
Milton Maenishi
I have a FinePix S1 and the display screen is not working. All other modes are working but no display
Many occasions LCD on camera display never fails but back light fails unless physical damage to LCD screen. Hold a torch to display when camera is on you will see faint(black and white) image means LCD is ok but back light is failed, it's replaceable but needs little skill to replace. Or replace full Screen with backlight. This is easy. Just remove back cover, remove display by loosening flex lock, put back new display carefully lock it holding flex with one finger. Please do not touch display flex contacts.
