20 Most Recent
Fuji FinePix 2600 Zoom Digital Camera Questions & Answers
How do I make an image file smaller so I can send it by e-mail?
To make an image file smaller for e-mail transmission, change the image file size in "Exif Viewer" or "FinePixViewer".
Changing the size of an image file
1. Start up the Viewer and select the folder containing the image you wish to send.
2. Double-click the thumbnail for the image file you want to resize to open the image in its own full-size window.
3. Select "Image size" in the "Image" menu.
4. Set "%" as the "Unit" used for file size display. Then enter a value lower than 100 as the "Width" or "Height" and click the [OK] button.
5. Select "Save as" in the "File" menu to save the image. (You can also reduce the image file size by lowering the quality in "Save as type".)
I can't get my new
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
THE BATTERY DOOR WAS
Welcome to Fixya
I dont think the battery door part is not available or sold separately in the market. Only Fuji has this part in their repair department. You may try to contact Fuji part store regarding this at 1 -866-289-3854.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
How do you transfer the
I have a Fuji F20. Before the computer will link up with the camera and find it, the power supply for the camera needs to be hooked up into the wall.
Here is a post from earlier I did for an Olympus camera. The instructions here should be the same for the Fuji.
http://www.fixya.com/support/t9107690-e_mail_photos
How do I reformat the
First Move the mode switch to the Play position then follow these steps
1 - Press the "MENU/OK" button to display the
menu.
2 - Use the left or right arrow buttons to select "ERASE" and then
use the up or down buttons to scroll to "FORMAT"
3 - Press the "MENU/OK" button
4 - You will see a confirmation message confirming that you want to format the card, Press the "Menu/OK" button to confirm.
Note - This will erase ALL of the picutures stored on the card whether you've protected them or not.
I was just given a
You can download and print the instruction manual in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Download Adobe Reader
To order a printed copy of the manual, kindly contact the Fuji Customer support department on
0844 553 2321 between the hours of 9 am and 5 pm, Monday to Friday.
You can also order the replacement cable on the above number.
For more help and clarifications, please feel free to reply to this post.
Your feedback is important to us. Kindly rate and accept the solution if you find it helpful.
Thanks for using FixYa.
When i turn my camera on it says "card erro" what
This may mean that the camera does not recognise the card because it is of too high a capacity (SDHC cards are not the same as SD cards) or it may mean the card needs formatting (because it is new or has become corrupted). There is a function in the camera menus to format or initialise a memory card.
When I try to take a pic Focus error appear
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
I need Battery Compartment Cover for .Fuji FinePix
proove to fiond it on ebay international seller is possible that you find in the world only the catch or it s possible that you find a entire faulty camera..and disassemble the catch form the camera..
i hope that i have help you. sorry for my english
When opening len cover I get display on monitor
I do not have a solution to this, but do share the same problem. This was my first digital camera and I was quite happy with the quality of the pictures until it stopped working. I have replaced the camera a long time ago, but wanted to give this little guy a second chance. I have tried to keep the lens open with a piece of tape, and am thinking of breaking it apart to see if I can remove the cover. Any ideas, anyone?
