20 Most Recent 3300 Radar Detector Questions & Answers
I have a rather old Whistler 3300 radar detector
Here are the steps from Whistler's FAQ page on their website:
When the display shows an "R1" type error on the display or the unit clicks (flashing either the Green power LED or the Yellow city LED), it means that the link between the inside and outside unit has failed. Generally this is caused by the receiver's (outside unit) cable becoming unplugged from behind the console (inside unit).
NOTE: The receiver cable is the straight one plugged into the "Radar 1" jack. The laser receiver (LRM-5) cable is angled and plugged into the "Laser" jack. This error will also occur if these two cables are reversed.
Follow the below steps to correct R1/Clicking error message:
  • Make sure the correct cable is connected to the correct jack and that it is fully engaged.
    Make sure there is sufficient slack in the cables to prevent them from "walking out" of the jacks.
  • Follow the Factory Reset procedure.
  • If the above suggestions does not cure the problem, email our Customer Service dept for more information.
Follow the below steps to correct R2/Clicking (Not available on Pro-3450) with "R" Yellow LED flashing error message:
  • If the rear antenna was not installed, go to the Factory Reset procedure. If a rear antenna was installed, continue to the next step.
  • If the rear antenna is installed, it must be programmed.
    For models 2270 and 2290
    1. Remove power from unit
    2. Press and hold the Dark button
    3. While holding the dark button, apply power to unit and hold the Dark button for 5 seconds. The "R"LED and either the Green (highway) or Yellow (City) will illuminate.
    For model 3300 and 3400
    1. Unit will display "R2 ON ?"
    2. Press the Dark button for Yes or City for No.
  • To temporarily cancel the "R2"error message on a 3300 or 3400 model, press and hold either the Dark/City/Quiet button.
  • Follow the Factory Reset procedure and see if the "R2" error goes away. If so, go to next step.
5/31/2011 5:47:06 PM • 3300 Radar... • Answered on May 31, 2011
2answers
Whistler 3300
Did you look at Whistler's website for R1 error trouble shooting steps?
5/15/2008 7:09:08 PM • 3300 Radar... • Answered on May 15, 2008
Specs for whistler 975 power cord what's the output
Product detailsCar charger For Whistler 925 945 975 1125 1200 Series Radar Detector Power Cable Power Payless All products are new and fully-tested OEM equivalent replacement parts Input voltage: 100V ~ 240Vac 50/60 Hz Overload protection Short circuit protection Over Temperature protection Power Saver Protection 100% HI-POT tested 100% cycling burn-inContact us for any question before leaving none-5 star feedback.Specialty Service in Power Supply,Satisfaction guaranteed ! How much power does a dash cam usePlease note that this is a quality compatible adapter, picture is justfor reference. It may looks different from the physical adapter youreceived. Sometimes, we even will send you a brand name adapter that is compatible with the one advertised.Source Link:https://www.newegg.com/toplab-hrnbl-b07kdjxn9l/p/0FB-06J3-00046?Description=cr93,whistler&cm_re=cr93,whistler-_-0FB-06J3-00046-_-Product
11/14/2022 10:11:22 AM • Whistler Vehicle... • Answered on Nov 14, 2022
I need a whistler 1140 superwideband 2.6 Lazer manual
Model doesn't exist :>( https://whistlergroup.com/pages/user-guides
11/12/2022 6:14:36 AM • Whistler Vehicle... • Answered on Nov 12, 2022
I have a whistler ws101 it says call a number what's wrong and how do I make it work
U need arepair book from company. Haynes or Clymer publish them also. Checout Pinterest or utube first
10/12/2021 4:32:07 AM • Whistler Vehicle... • Answered on Oct 12, 2021
Whistler WS-1065
Whats the problem?
12/19/2020 4:38:53 PM • Whistler Vehicle... • Answered on Dec 19, 2020
How to perform a factory reset on whistler WS1025 scanner
Configuring Your Scanner
Preprogrammed Frequencies
Your scanner includes 153 preprogrammed frequencies, which you can load into Channels 1 to 153. For a list of these frequencies, see "Preprogrammed Frequency List" on page 23. To load the pregprogrammed frequencies: 1. Turn off the scanner and then turn it on again. 2. While WELCOME message appears, press PGM. 3. Load -Fr- appears, then YES--Ent and No -- CLEAr appear alternately. 4. Press ENT to load frequencies or CLEAR to cancel.
Programming Channels
If you do not have a list of frequencies in your area, refer to www.radioreference.com. 1. Press PGM. PGM appears. 2. Enter the channel number (1-200) where you want to store a frequency, then press PGM again. 3. Use the number keys and • to enter the frequency (including the decimal point), then press ENT. 4. To program the next channel in sequence, press PGM and repeat Step 3. To program a specific channel repeat Steps 2 and 3.. • Your scanner automatically rounds down to the closest valid frequency. For example, if you enter 151.473, your scanner rounds it to 151.470. • If Error appears and the scanner beeps three times when you press ENT, start again from Step 2. • If the frequency is already stored in another channel, the scanner beeps three times and displays -dUPL- (duplicate) and the lowest channel number where the frequency is already stored. Press TUNE/CLEAR to cancel. Press ENT if you still want to store the frequency.
1/27/2020 7:02:30 PM • Whistler Vehicle... • Answered on Jan 27, 2020
Whistler wbu 900 activation bypass S
Use the serial number from the device and contact customer relations. It worked for me.
7/11/2019 3:51:11 PM • Whistler Vehicle... • Answered on Jul 11, 2019
Whistler 1010 is a year old, it worked good till unplug now it does not come on like no power , I have a tester and i'm getting power but it does nothing why ?
check and see if there is a fuse in the plug on the end of the wire, sometimes when you unplug those the fuse can blow in them
4/15/2019 1:02:35 PM • Whistler Vehicle... • Answered on Apr 15, 2019
What's vg2 mean on 1530 Whistler
The VG-2 button is to engage VG-2 Cloaking Technology. From what I can see VG-2 Cloaking Technology is a way the detector has of avoiding being detected by authorities in areas where the use of radar detectors is prohibited. I am not in a position to say how effective this is, I suggest you refer to reviews. I have only researched the meaning of VG-2.Rider here: Please do your own research on the effectiveness of this technology on this - or any - detector.Of course the best way to avoid being picked up for speeding is not to speed. (But you knew that..)
3/6/2019 10:46:30 AM • Whistler Vehicle... • Answered on Mar 06, 2019
NEED CODES AND HOW TO SET A WHISTLER XRT 335
Some fixya user told me a website reliable-store it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try free
1/23/2019 11:54:17 AM • Whistler Vehicle... • Answered on Jan 23, 2019
Planning on buying a trx2 Whistler , what web sightncan I find frequencies in zip code
looks like it's hard to get.. why don't u try online some websites deal in it real time.. along with solutions to problems how to repair fix service nd all let me know if u need some help in this
1/22/2019 11:43:06 AM • Whistler Vehicle... • Answered on Jan 22, 2019
My sound isn't working on my whistler pro78se
There's a website that has all this information about all this and manuals everything totally free there are many actually but I personally like few .. 'let me know if u need help thanks
1/21/2019 10:22:49 AM • Whistler Vehicle... • Answered on Jan 21, 2019
How do I get a activation code for a whistler wbu 900 monitor? If I bought it from an individual and not a consumer
There's a website that has all this information about all this and manuals everything totally free there are many actually but I personally like few .. let me know if u need help thanks
1/21/2019 10:19:31 AM • Whistler Vehicle... • Answered on Jan 21, 2019
Bypass pin code for a whistler ws1010wp
1/21/2019 10:19:24 AM • Whistler Vehicle... • Answered on Jan 21, 2019
Can the whistler ws1010 scanner have a hard reset done?
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything someone on fixya recommended it to me and I thank him even today They have full manuals and it's verrrrry cheap and mine I got free in offers 3rd time I also had an issue with the file so the girl replaced it in 30 mins there is one more but i don't remember its name it was 2 years back bitman something link this Try it out brother
1/19/2019 11:47:48 AM • Whistler Vehicle... • Answered on Jan 19, 2019
3300 Radar Detector Logo
2 questions posted
Top Whistler Vehicle Parts & Accessories Experts
Ngoro
Arnie Burke
Arnie Burke
Are you a Whistler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Whistler Vehicle Parts & Accessories
Most Popular Question
rather old whistler 3300 radar detector
  • Vehicle Parts & Accessories
