20 Most Recent
Uniden BC248CLT Base Scanner Questions & Answers
Clear Channels
On SOME of these radios, you can hold down the #2 key and the #9 key at the same time that you turn the radio on, and it resets all data in the scanner. Let me know if that works.
How do i stop costant satic
question first.... are you using an external antenna ie outside or set top inside?..............are you using an external power supply ie power box or battery?.............has yor receiver got a signal meter in it, if so whats the static signal strenth?
jon d
Cant stop squelch
first take your scanner away from its currant soroundings and try it in someone elses house cause there is so much interference out there eg worn electric motors in fridges or heating pumps or plasma tv and certain 30" and above tvs, that one could even come from nerxt doors tv. next thing to try is put in an earth spike directly from the scanner to the ground ( has to be mud) or move your arial but try it elsewhere first then youl know if its in or close to your house.
Radio scanner not receiving
i ha ve realistic 2032 which is doing the same thing and was wondering because everything else including all the functions work fine including hearing white noise and being able to control it with the squelch could this be the end for it or is there stuff yet to do
Bearcat BC144XL Scanner ~ no sound
Try it with an external speaker. The external speaker jack receives the audio from the scanner before it goes to the internal speaker. If the jack thinks there is still something plugged into it, the audio to the internal speaker is interrupted. If the jack is stuck, it may still work with an external speaker.
