20 Most Recent Sylvania 6419TC 19" TV Questions & Answers
2answers
I need the code for to program a universal remote
Hello
Three digit remote code for sylvania are:-
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 133/ 161/ 163
Four digit remote code for sylvania are:-
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
NB: Switch OFF and Switch ON the TV by its front panel POWER SWITCH [not by remote control handset] each time before trying an other code.
OK.
4/3/2015 1:21:46 AM • Sylvania 6419TC... • Answered on Apr 03, 2015
How do I change the aspect ratio to m Sylvania tv. I used the menu button but there is not an option for the aspect ratio.
You should use its remote control to adjust this. With panel controls, you can't. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
10/19/2014 9:18:31 AM • Sylvania 6419TC... • Answered on Oct 19, 2014
Charter remote control codes11864,10171,11271,11314,
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
7/24/2014 6:56:32 PM • Sylvania 6419TC... • Answered on Jul 24, 2014
3answers
Sylvania 6419TC
My Sylvania T.V. turns on and then it turns off by itself. It only stays on for onr minute.
6/11/2014 5:48:50 PM • Sylvania 6419TC... • Answered on Jun 11, 2014
How to put on game mode
You need to buy a universal remote in order to change the input mode.
4/8/2014 8:09:44 PM • Sylvania 6419TC... • Answered on Apr 08, 2014
Keeps shuting off every 1minute since about 2days
If horizontal output transistor is faulty [leaky], this kind of fault can occur. Check by replacing it by a new one of same number. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
11/3/2013 9:19:08 PM • Sylvania 6419TC... • Answered on Nov 03, 2013
manual
I have a zenith tv with no remote how do i change the channels on it
As there is no menu button at its front control panel, you must have its remote control to select its input.
1/17/2013 2:09:43 PM • Sylvania 6419TC... • Answered on Jan 17, 2013
8answers
Unable to turn on video mode without remote. I dont have remote
Who the hell builds a TV w/o a AUX or video button on the TV.... i hate this darn sylvania...
11/18/2012 4:01:25 PM • Sylvania 6419TC... • Answered on Nov 18, 2012
What is the code for a universal remote for a sylcania model sst4274s
Four digit universal remote codes for Sylvania TV are: 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161Three digit codes are: 004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 133/ 161/ 163
To know more about the setup method, Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
10/17/2012 2:38:01 PM • Sylvania 6419TC... • Answered on Oct 17, 2012
I have a sylvania tv 19 in with codes on tv and our universal remote will not switch channels and the volume is not working on the tv, also the buttons on the tv will not work. How can i fix it.?
This is not a fault with TV or remote control. Some codes will not work for all functions. Just try an other code for your TV. You can get it from the code list of the remote control. Try synchronising an other one. Select one code, which have maximum functionality.
6/13/2012 4:38:19 PM • Sylvania 6419TC... • Answered on Jun 13, 2012
Are there fuses in my Sylvania TV that is about 9 years old?
Yes. There should be. Check the main power regulator circuit side. A glass cartridge type fuse, rated 3.5Amps will be there. It can be replaced.
5/28/2012 12:24:34 AM • Sylvania 6419TC... • Answered on May 28, 2012
2answers
Sylvania 6419TC 19" TV Logo
51 questions posted
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
zenith tv no remote change channels
  • Televison & Video
