20 Most Recent
Sylvania 6427TE 27" TV Questions & Answers
Can you help me find all 3 digit codes for sylvania the ?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
How to connect sanyo dvd and vcr combo player DVW-6100 to older tv
On older tv sets there are limited inputs...one for video and one for audio..
Find the white output hole for video on the back and run the cable to the set, and as for the audio there will be 2 red output holes (left and right on your dvd/vcr combo unit) this will use a special cable you can buy at radio shack that converts the left and right to just one output(it's like a "y" looking chord. it will still work if you just use one audio chord "out" from the dvd/,vcr unit but you will be hearing only one side of the "Stereo"
plug these into the back of your old set the white is for video and the red is for audio.
What to do if screen show now scanning and i can not get if off
Let the channel scan complete fully. This just needs to be done once for antenna channels and once if you use cable. Should take about 5 minutes to complete, but if u must interrupt or exit, press menu, or power to turn off TV. Make sure the tv's tuner setting is set appropriately for either cable or air (antenna), depending on your way of receiving channels, so it scans and finds properly.
Xbox
I have the same problem with a 6420ff sylvania tv with a xbox 360. I plug the red white yellow into the front of the tv and it wont come on.
