20 Most Recent Sony STR-DE875 Receiver Questions & Answers
Sony STR-DE875 receiver has no sound from right
Hy all. I bought a receiver at last week. But the front speakers not working. The rele is jumping just.i repaired them ! the rele colour is blue. Three percent . left first -Center, between -Surround, between(right Hand)-Front.I moved the front channel's rele(right hand) .Katt -it sad. Working, volume is back. Rele specification is (colour Blue) Deg Greatings-Ranger of Hungary.10_26_2012_6_50_16_am.jpg
9/14/2014 6:27:37 AM • Sony STR-DE875... • Answered on Sep 14, 2014
Remote work properly
Make sure the batterys are good if so open the remote and check the led that send the signal it may be unsoldered
12/17/2013 5:22:10 AM • Sony STR-DE875... • Answered on Dec 17, 2013
Problem with SONY STR-DA555ES home stereo receiver
You may have the speakers incorrectly connected or the speakers you are using have an impedence that is too low for the amp to support.
10/19/2013 3:30:45 AM • Sony STR-DE875... • Answered on Oct 19, 2013
Sound cuts out with "protector" message
Sounds like a bad speaker, or a speaker that is being over-driven.
4/23/2013 7:17:17 PM • Sony STR-DE875... • Answered on Apr 23, 2013
Str-de875. Remote is suddenly not making the amp work. the remote still turns tv on/off
does the light blink more than once when you select the 'contol the reciever now' button? I assume you push a button to switch which device the remote will control, and then push another button to astually have the device do something
4/11/2013 10:07:48 PM • Sony STR-DE875... • Answered on Apr 11, 2013
My receiver is getting power from the outlet, I
What did Sony have you do that DID NOT work? We don't want to re-invent the wheel here.Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on. Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up. You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it. If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good. If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
7/27/2011 2:10:36 PM • Sony STR-DE875... • Answered on Jul 27, 2011
Sony STR DE875 5.1 --- It has no display and no
Sounds like your powersupply is going bad. Try going to Sony Esupport.com flat rate calculator.
4/9/2011 12:15:34 AM • Sony STR-DE875... • Answered on Apr 09, 2011
0answers
2answers
Center speaker works intemittantly... right front
I would suspect that the center speaker wiring is not connected securely either at the speaker or at the amp or the wire has a intermittent break in it. I would replace that wire. The right front speaker wire I would suspect is shorted out which will cause low volume. It can also be the wire is too small which will also cause low volume. Replace that wire also. If this does not cure the problem then there is a problem with the amp or the speaker itself. Try switching the left and right speakers and if the problem moves to the left speaker you know that speaker is the problem. Make sure that one of the fine wires is nit touching the chassis of the amp at the connection.
9/2/2010 1:06:26 PM • Sony STR-DE875... • Answered on Sep 02, 2010
Sony str-de875 amp. one speaker louder than the rest
hi. i have a sony amplifier. i plug the speakers in like normal. i turn it on and the right side speeker works fine. but you half to crank it up all the way just to barely hear the left speeker. we switched speakers and its still the same effect. we think its the amp itself. we tried our balance settings. it was fine. but right now its just playing one speaker louder then the left one. can anyone help me?
3/18/2010 10:14:58 PM • Sony STR-DE875... • Answered on Mar 18, 2010
Sony STR-DE875 Receiver Logo
Popular Tags
43 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sound cuts out protector message
  • Audio Players & Recorders
