20 Most Recent Sony STR-DE345 Receiver Questions & Answers
Shorted output transistors.
Sony STR-DE345... | Answered on Jun 03, 2018
the clicking is a power suplie overload some output amp is with problems and shutdown after overheat, when you tap is bad connection inside, normaly is related with sound off after 15min. needs to be checked by tech. to ensure perfect operation.
Sony STR-DE345... | Answered on Jun 04, 2016
The manual says it thinks there is a short circuit on the amplifier output side. If it still says Protect after disconnncting all the speakers wires there is an internal problem. Take it to a hands-on tech.
If the problem disappears, you had a short. Attach speakers one at a time to isolate the cause.
http://www.retrevo.com/support/Sony-STR-DE345-Receivers-manual/id/387bh943/t/2/
Sony STR-DE345... | Answered on Jun 03, 2016
hi,
i can download it for you..
visit this site for manuals of your unit it will help you answer all your questions.
http://www.free-service-manuals.com/Detailed/15736.html
thanks,
you rate in our answers are much appreciated..
Sony STR-DE345... | Answered on Dec 12, 2015
Are all the speakers GOOD and all connected right?
If so then you have at least one blown output amplifier module.
Sony STR-DE345... | Answered on Dec 28, 2013
This usually means there is a short in the amp section. It needs to be looked at by a pro.
Sony STR-DE345... | Answered on Dec 26, 2012
Your device has went into protection mode, an internal malfunction causes it to shut down in order to protect itself.
Somtimes a physical reset will help.
Turn of and unplug device fro a couple of hours
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Sony STR-DE345... | Answered on Feb 16, 2012
The buzzing is caused by the power source of the receiver : the filtering capacitors from the power lines to the amplifier circuits have aged and have started to dry, lose their capacity so the current is no longer filtered correctly so the ripple from the AC mains is stronger and it's passed on to the amplifiers where it became audible.
Keeping the capacitors under constant tension will help them regenerate somewhat, but you will have in the end to replace them. A simple job, just be careful at the ratings of the capacitors when you get their replacements.
Sony STR-DE345... | Answered on Jul 26, 2011
Hello, that happens when a reciever gets a few years old and only the remote control has been used.The switches are dusty i recommend pushing them in 50 times each ,i know it sounds silly but it will clean the contacts.
Sony STR-DE345... | Answered on Feb 22, 2011
If it's not heat you may not be able to resolve it yourself. A technician might.
Sony STR-DE345... | Answered on Feb 21, 2011
The center channel on this model uses its own amplifier circuit that is independent from the others. It is usually a 5-9 pin IC attached to the heatsink. It is likely that this IC is defective and needs to be replaced. Unfortunately, I can not know this for sure without taking measurements inside the unit. There is no simple fix for this although this is an easy repair for a service shop. Please seek professional assistance to resolve this. Expect a parts cost in the $25 range.
Dan
Sony STR-DE345... | Answered on Jan 28, 2011
May be a number of things...the power supply may have a shorted component in it...or the audio output stage may be defective...if you can obtain a volt/ohm meter you can test the power supply diodes and the regulator/audio output transistors...you will need to use the diode check function or the ohm scale to check these semiconductors...they should read infinity in one direction and , on diode test, anywhere from 500-700 for silicon(which is what is used today)..on the ohms scale you should read 500-2000 ohms in one direction and infinity in the other...if you get a 0 reading on any of the semiconductors..then it is shorted and will need to be replaced
Sony STR-DE345... | Answered on Jan 07, 2011
Sony STR-DE345 Receiver Logo
63 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
loud buzzing sound in
  • Audio Players & Recorders
