20 Most Recent
Acme 5001 Supreme Juicerator Juice Extractor Questions & Answers
MAKES A LOUD NOISE
disassemble clean and assemble paying attention to condition
noise from bearings going out/screeching ???
noise from unbalanced load/ lots of vibration??
noise from scraping/grinding/metal on plastic ??
noise from scraping/grinding/plastic on plastic ??
there any burning smell also ??
is any part getting warm ( turn upside down to check ) ( hold or place on thick layer of kitchen towels
be aware if it is old ~ 20 yrs give or take 20 yrs getting a new juicer will be less hassle than trying to repair
4/2/2019 3:18:51 PM •
Acme 5001...
Answered
on Apr 02, 2019
Acme Supreme Juicerator 6001 Model # 11JE21
REMOVE THE COVER BY ROTATING AND
THE CLUTCH NUT HOLDING DOWN THE
CUTTING BLADE. EVERYTHING LIFTS OFF.
CLEAN ALL DISCOLORED PARTS BY FIRST
BOILING IN A SOLUTION OF OXI CLEAN AND
WATER, THEN SCRUB WITH A SAFE
ABRASIVE SPONGE. SHE WILL SHINE UP
NICE.
5/8/2013 2:12:58 AM •
Acme 5001...
Answered
on May 08, 2013
Acme Juicer
Are both of the metal parts that you twist the top onto still sturdy? One of mine is broken, and I have to find a replacement part.
1/6/2013 11:43:48 PM •
Acme 5001...
Answered
on Jan 06, 2013
Why does my supreme juicerator shake and make
the rubber banding on the bottom of the shredder disk gets worn over time and you might need to buy a new shredder disk. I was experiencing the same problem (the juicer was vibrating at an odd speed,shaking and the sound of the motor was distressed, when the plunger was inserted to push down the veggies it was banging and making an awful noise) replacing the disk solved the problem - good as new.
4/25/2012 2:40:14 AM •
Acme 5001...
Answered
on Apr 25, 2012
Acme Juicer
WARING HANDLES THEM AT 800 492 7464.
HOW OLD IS IT? BEARINGS COULD BE GONE.
THEY ARE REPLACEABLE.
2/16/2012 8:24:39 PM •
Acme 5001...
Answered
on Feb 16, 2012
How to keep your juicer from jumping all over the place.
I have found celery is the big problem, instead of putting in the whole stalk cutit into small 2 inch pieces, when I do this I have no problem, otherwise myjuicer is jumping all over the counter. I believe it is the long strings in thecelery that somehow gets caught around the parts. At least it has madejuicing a pleasure for me. Hope it works for you. If this has helped you please let me know,
[email protected]
Motor runs and is seem like it has a clutch that
The white impeller that you attached the basket and blade to is
keyed to the motor shaft. There is a small shallow nut that you
can remove with a needle nose pliers and pull the impeller off
the shaft to see if it's seated properly or damaged. If damaged
talk Waring into selling you another at 1 800 492 7464.
4/26/2011 6:00:29 AM •
Acme 5001...
Answered
on Apr 26, 2011
I have an acme juicerator
You may have tripped the reset button on the bottom of the juicer, just push
it back in. They really don't have to warm up, just give it a few seconds to reach
speed.
4/26/2011 5:52:08 AM •
Acme 5001...
Answered
on Apr 26, 2011
Filters
Do without them. They lessen the yield and cleaning
the juicer is not that difficult.
1/30/2011 5:58:32 AM •
Acme 5001...
Answered
on Jan 30, 2011
