20 Most Recent
Meade ETX-60 AT Telescope Questions & Answers
I have an older model meade etx astro telescope i
Can you see Light through it during the day time? If you can nothing is wrong. Put the eyepiece with the largest number written on it into the TOP and try focusing on a distant object during the day time.
Turn the focus knob until you get a sharp image.
My ETX-60 remote turns on
About the only thing you can do is buy another hand controller-- contact Meade for a new one.
I am assuming the hand controller cable cannot be replaced check it anyway and see if you can get someone to replace the plastic plug that goes into the telescope on the cable. Sometime these go bad. Any "network" cable guy should be about to replace the end.
http://www.meade.com/support/index.html
My telescope is only slewing
Either the buttons are STICKING on your hand controller, or the hand controller cable is defective.
Contact Meade customer service:
Adjustment lever part is for
Contact Meade directly for any replacement parts. You might also find something at a well stocked hardware store that will also work.
Meade ETX-60 Horizontal drive
The AZ worm gear is not engaging the gears. There is a spring next to the gear which applies pressure -- open up the base and see if the spring is loose or broken.
60at motor fault
Could be several things:
You did Train the drives and CALIBRATED motors using the same power source you will use outside?
Do not run off of the internal batteries UNLESS they are brand new. Once the batteries drop below about 70% the hand controller goes a little crazy. That's why most people use an external power pack.
1. Replace the batteries, and do a Calibrate motors.
Did this fix it?
