20 Most Recent
Zyxel (91-004-361002) Wireless Router Questions & Answers
I've forgotten my security password
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and configure it again.
To reconfigure your LinkSys, connect a PC to one of it'sEthernet ports, load a web browser, and go to the URLhttp://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." While newer models, both the default username and the default password are set to "admin."
Once you go past the login screen, you should be able to reconfigure the LinkSys router.
Here are some of LinkSys Router models along with its Default usernames:
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys WRT54G, BEFW11S4: admin
Linksys Comcast routers: comcast
All other Linksys routers: {none}
Here are some of LinkSys Router models along with its Default passwords:
Linksys Comcast routers: 1234
Linksys BEFW11S4: {none}
All other Linksys routers: admin
For those [none] username/password entries listed above, no name or password is required. Just skip or press the Enter/Return key when prompted for those settings.
11/23/2017 10:46:28 AM •
Zyxel...
Answered
on Nov 23, 2017
Password forgot
Check the Bottom of the Router.... if your using a none stock password then you got to reset it so unplug it and hold the reset button for about 30 seconds then plug it back in should reset to stock
10/13/2013 9:52:56 PM •
Zyxel...
Answered
on Oct 13, 2013
Setting up a new modem
After you press the reset. Your laptop has to be physically connected to the router to configure it Open your web browser, type in "192.168.1.1" and login using username and password. In "Basic setup" DHCP Server should be "Enabled" Enter "Domain name" Name your private network Set the starting IP address - Enter 10 ( any low number) Set time zone Save Settings ( button at bottom of page ) Under Advance Routing, set Operating mode as "Router" Save Settings WIRELESS TAB Wireless - set to MIXED Wireless network name - same as domain name Select a wireless channel (default is 6) Wireless SSID Broadcast - ENABLE Save Settings Wireless Security tab Select WEP Default transmit Key - select 1 Enter a pass phrase to generate a security code, click on Generate WRITE DOWN THE PASSKEY ( aka, Security code) KEY 1 should have this PASSKEY entered. SAVE SETTINGS On your laptop, right click on the icon for the wireless on the task bar, select "View available networks" Select your network, it should prompt you for the passkey, you will need to enter it twice
1/8/2013 7:14:59 AM •
Zyxel...
Answered
on Jan 08, 2013
Pk5001Z
Try changing the location, as high as you can. Add a better Antenna. Change channels.
12/4/2012 5:42:24 PM •
Zyxel...
Answered
on Dec 04, 2012
I HAVE FORGOT MY PASSWORD
Hold down the reset button on the router for 30 seconds and that should reset it all to factory setting including the password, which should be on the bottom of your router
11/29/2011 6:44:03 AM •
Zyxel...
Answered
on Nov 29, 2011
Hello!
I have a ZyXel Prestige
Go into your Modems status tab and look under the device table subsection. it should list all the connections and there IP address. Punch in that and you should be good.
11/29/2011 6:40:44 AM •
Zyxel...
Answered
on Nov 29, 2011
Forgot my password for wireless router 660hdt
There are two different things. One is the Login/ Password to log in to the router user interface for configuration. Second is the Network Key, which you have to provide to get access to the internet. If you have forgotton the Network Key and know the login/ password, you can log on to the router settings and reset the Network Key.In case you have forgotten the login/ password of the router, ALL YOU CAN DO IS TO RESET THE ROUTER TO FACTORY SETTINGSYou may reset router to factory setting from the reset button on the
back side of the router. It may be a push button or else use a paper pin to press the button for few
seconds, the lights on the front would blink and the router would
restart with factory setting. Please not that ALL SETTING WOULD BE
LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN. Configuration may be tricky sometimes and you have to secure the network/ router.Hope it helps! Good Luck! Thanks for using Fixya!CreativeTECH
10/17/2011 7:42:55 AM •
Zyxel...
Answered
on Oct 17, 2011
