20 Most Recent
Sony DAV-C700 System Questions & Answers
Adjust treble
is it too much treble and you want to attenuate?
if thats the case i have a simple suggestion. wire used for doorbells has no place between an amplifier and a speakers. you could try obeying for a set of modus cube speakers. they're great and cheap. between 10 and 25 GBP a pair. you may even be able to find the centre speaker. if not just get 6 speakers or 3 pairs. use 5 of the 6 and keep a spare.
wharfdale modus cube main speakers
or
Wharfedale Modus Cube Main Stereo Speakers
theres 2 sets easy to find.
What is this optical cable looks like & use for
The optical cable can be used if you have a surround receiver or a soundbar with optical inputs. It can carry digital audio from a flat-panel television to either of these devices, and the sound is much more defined than if you use RCA cables.
I have a Toshiba CF30C50
First of all reset all settings to factory defaults.
There is problem in speker or connection to speaker.
You can test that all connections are ok or not?
Sony DAV-C990 can't get it off the standby mode
Unplug DAV-C990 from AC outlet for couple of minutes, replug back in and power it up.
If problem still exist then home theater has got problem in amplifier output section. Let me know the results to help you more.
The DVD an CD doesn't work
Check speaker connections and wires and make sure all wires are plugged properly. If problem still exist then unplug speaker one=by-one and test home theater to determine what speaker is causing Protect error.
Poor picture quality
A lot of "aged" problems relate to the power supply with this type of unit. If you are a handy chap and know what capacitors are you will find that finding and replacing the "dry" caps in the power supply will fix most problems including streaky pix and crackly audio.
Power
Sony DAV C700 DVD Player
Sony dav-c990 not functioning
DAV-C700 overheated
Lines on tv
C-81 error, disc won't eject
