20 Most Recent
Sony CD Radio Cassette Boombox, CFD-E90 White : CD Player Questions & Answers
Sony boom cd/radio/cassette player says
The laser diode is usually the first component to fail in optical disc players.
If you can, open the casing to expose the CD mechanism.
Point a cell-phone camera at the laser lens, which hides under a flat bridge.
Without a disc inserted, press play or eject / load the CD tray.
Via the camera, you should see the laser diode briefly flash as it tries to read data from where disc should be.
No flash means IR laser diode has probably burnt out.
Don't stare directly into laser beam for long periods with the ***** eye - rather use the camera as an interface.
The beam's visual color is red, but the CDS sensor of a digital camera sees the IR radiation as white on mobile's screen.
CD Player won't read disc
sounds like the cd mechanism is not completly loading, or chucking..when you tip it back the cd can move freely, need to check belts, possibly slipping
I need a replacement Antenna
You can get a replacement antenna at any Radio Shak. Take the portable radio with you to the store and they will help you find the right one and even install it at no extra charge.
I put a extra bass
It's because there is to much wattage for your reciever to handle. Your reciever can't handle your speakers.
The tape plays songs so fast sounds like donald
Hi, the casette deck has a mechanical system (servo-driver) most of the problems that happen when in your case, plays song so fast is that you look at the pinch roller. The pinch roller is a rubberized free spinning wheel typically used to press
magnetic tape against a capstan shaft in order to create friction necessary to drive the tape along the magnetic heads with a normal tape speed if the pinch roller brakes, get lost from his place or got dirty then you get this fast sounds play, check the pinch roller if still good in his place or clean his rubber with alcohol, then the problem should be fixed.
I have a cd player it reads and play but no
the headphone jack has a short. make sure there is nothing stuck in the head phone jack. (the little hole you stick head phones into) 2 the amplifier is faulty but i don't think thats the problem. (i would have had to got soaked in water to do that) hope this helps.
It is not a CFD-E90 White CD player, but is Red
There is spindle motor that spins the disc, pull up spindle table slightly as this will increase gap between disc and lens so lens would be able to read data in mid tracks easily.
In my opinion, disc table mounted on spindle motor got incorrect position and creates less distance between disc surface and lens that is causing problem for lens to read the data from disc.
CAUTION: adjusting disc table is tricky job and novice can break it easily so do it carefully without damaging it. Insert flat screw driver at bottom of table where is meats with spindle motor shaft and turn screw driver slightly to push upward that disc table.
Thanks.
Cannot set time
> press and hold clock/sleep/timer button
> turn dial to set hour
> press enter button
> turn dial to set minute
> press enter button
now, your clock should be in working order! :)
Need user manual
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDE90&LOC=3
here is the manuel.
thanks for choosing FixYa
Connecting SONY TA-D505 amplifier LBT-D505
Hi David, do you want to connect the ST-D505 tuner to the TA-D505 amplifier?
You just have to connect an audio cable of two RCA (red and white) from the audio output L and R of the tuner ST-D505 to the input of Tuner in the amplifier TA-D505
Remember to connect the FM antennas and the AM Antenna Loop on the ST-D505 tuner
To listen to it, you have to select Tuner on the TA-D505 and enjoy the favorite radio stations
I hope you have my comments
Greetings Franco Dosil
Hola David, quieres conectar el sintonizador ST-D505 al amplificador TA-D505?
Simplemente tienes que conectar un cable de audio de dos RCA(rojo y blanco) desde la salida de audio L y R del sintonizador ST-D505 a la entrada de Tuner en el amplificador TA-D505
Recuerda conectar las antenas de FM y la Loop Antena de AM en el sintonizador ST-D505
Para poder escucharlo, tienes que seleccionar Tuner en el TA-D505 y disfrutaras de las estaciones de radio preferidas
Espero que te sirvan mis comentarios
Saludos Franco Dosil
https://elektrotanya.com/sony_lbt-d505_d505cd_d505cdm_d505m.pdf/download.html
The display does not work on my Sony CDP-CE375 CD Player.
troubleshoot the issue:
Reset the CD Changer:
Turn off the CD player.
Press the CLEAR button.
Simultaneously, press and hold down the POWER button on the CD player for 60 seconds.
If this doesn't resolve the issue, proceed to the next step.
Check for Error Messages:
If you encounter difficulty playing a disc and receive any of the following error messages, there may be an incorrect setting or a problem with the disc:
NO DISC
DISC ERROR
CD ERROR
TOC ERROR
Refer to the instructions supplied with your CD player to verify model-specific information and troubleshoot the issue.
Internal Component Repair:
If the display issue persists, it might be related to an internal component that requires repair.
