20 Most Recent Samsung Rugby 2 ( Rugby ii) A847 Two Tones, and Hard Case/Cover/Faceplate/Snap On/Housing/Protector Questions & Answers
2answers
Block incoming text
In iOS 7, there is an update that allows you to 'Block the Caller' this should block Text Messages and Calls from that number. If that does not work, you can reach out to Law Enforcement about the harassment, or your Cell Phone carrier to block that number all together... Best of luck with that.
11/1/2016 2:05:51 AM • Samsung Rugby 2... • Answered on Nov 01, 2016
I just got an unlocked Samsung Rugby II and am unable to make or receive calls - even though my new carrier has activated their SIM card. I have full bars. All of the contacts I keyed into my phone ar
If you just put your sim in you might need to give it 24 hours to provision. Also, if it doesn't work, check with your carrier. You might have an incorrect sim in there. There has been modifications to the chips and some of the older ones that had no problems do not work in newer phones.
12/18/2014 8:58:48 PM • Samsung Rugby 2... • Answered on Dec 18, 2014
How you I turn up the volume on the ear piece
On my Samsung phone, I just put the volume up while talking on the phone. Anytime, press the volume key, and if a visual appears on the screen, tap the gear to the right and it will open up options for different types of volumes. The other way should be to go into your settings and choose sounds.
12/11/2014 5:07:47 PM • Samsung Rugby 2... • Answered on Dec 11, 2014
Block number from samsung rugby cell
All depends on your provider. Check with them. It might be a simple setting or they have to do it manually.
10/26/2014 7:12:09 AM • Samsung Rugby 2... • Answered on Oct 26, 2014
How do I adjust the volume on a rugby II cell phone
Are you wanting to adjust the ringer volume? If so, open the phone, tilt phone to the right 45 degrees, the two bottom buttons on the left side are for ringer volume control, up and down. As far as volume control into the ear , it is the same left side control buttons. Volume is from 0-7, 7 being the highest. That is how it is on my Rugby phone. Good luck.
1/21/2014 3:58:48 AM • Samsung Rugby 2... • Answered on Jan 21, 2014
Forgot password unlock phone
A factory reset is the only way buddy
7/30/2013 1:42:44 AM • Samsung Rugby 2... • Answered on Jul 30, 2013
Need to download contacts from phone to computer
just download the required software (depends on the type of model you have) to your system, connect the device to the system and now you can transfer....
2/4/2013 12:59:06 PM • Samsung Rugby 2... • Answered on Feb 04, 2013
0answers
How to unlock
You can get the Unlock code from the site Simpleunlocking.com/supported-phones/rs16wp7/ and get free unlocking instructions at Mobileunlockguide.com/samsung-sgh-a847-rugby-ii and unlock it easily.
7/6/2012 6:05:43 PM • Samsung Rugby 2... • Answered on Jul 06, 2012
How to download picture from cellphone to pc
Hi,If I understand you correctly you wanted to transfer your pictures from phone to pc. To do this please see steps below. There are two ways to transfer the images from your phone. A. Using the Bluetooth Feature.(Please note: Your PC should have a bluetooth capability to do this)1. Enable the bluetooth device of your phone. Settings -> Connectivity -> Bluetooth2. Go to picture viewer and select a picture and press the "Option" soft key 11_23_2011_5_12_27_pm.gif.3. Select "Send" and choose sent via Bluetooth. 4. Your phone will scan available bluetooth devices and you must select the name of your pc. B. Using the USB Method. This method is more practical and faster way to transfer images from your cellphone. 1. You must have a microUSB v2.0 cable. (This may have been included in box of your phone if not you can purchase this separately). Please see screenshot below. 11_23_2011_5_19_04_pm.jpg2. Download and Install Samsung PC Studio Software. Click here to download. (when the download screen pops up just hit "Run".3. Connect the USB adapter cable to your PC. A USB icon 11_23_2011_5_24_34_pm.jpgdisplays on the screen when an active connection is established.
4. In Idle mode, press Menu ->Settings -> Connectivity. Select USB Mode and press the Select soft key or the key. Use the Up or Down Navigation key and highlight this option:
• PC Studio: is set to launch PC Studio as the default application
when a USB connection is detected.
Press the Save soft key or the key5. Open the PC Studio program, usually it will create an icon in your desktop. 6. Select Manage Files and it will give you the list of folders you have in your phone. For more detailed step by step instructions on how to transfer images from your phone please click here. Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
11/23/2011 5:57:48 PM • Samsung Rugby 2... • Answered on Nov 23, 2011
How do i down load a free manual for samsung rugby
Hello Sir just click on this link below and the user manual for samsung rugby 2 will open
http://images.wirelessdealer.ca/images/phones/userguide2628.pdf
Thanks for using fixya :)
8/6/2011 7:10:09 PM • Samsung Rugby 2... • Answered on Aug 06, 2011
Samsung S9 turning Samsung Music app on by itself
It sounds like there might be a glitch or an issue with the Samsung Music app on your Samsung S9. Here are some steps you can try to troubleshoot and potentially resolve the problem:
  1. Force Stop and Clear Cache:
    • Go to Settings on your phone.
    • Scroll down and select "Apps" or "Applications Manager."
    • Find and tap on "Samsung Music."
    • Tap on "Force Stop" to stop the app.
    • Then tap on "Storage."
    • Tap on "Clear Cache" and "Clear Data."
    • Restart your phone and check if the issue persists.
  2. Update the App:
    • Make sure you have the latest version of the Samsung Music app installed on your phone. Go to the Google Play Store, search for "Samsung Music," and see if there's an update available. If yes, install the update and check if the problem is resolved.
  3. Check for Rogue Apps:
    • Sometimes, third-party apps can interfere with the normal operation of other apps. Try to remember if you installed any new apps around the time this issue started happening. You can try uninstalling recently installed apps one by one to see if the problem goes away.
  4. Reset App Preferences:
    • Tap on the three-dot menu icon in the top-right corner and select "Reset app preferences."
    • Confirm the action. This will reset app permissions, notifications, and any default apps you've set.
  5. Factory Reset (Last Resort):
    • If none of the above steps work, you may consider performing a factory reset on your phone. This will erase all data on your phone, so make sure to back up important files and data before proceeding. Go to Settings > General Management > Reset > Factory data reset.
If the issue persists after trying these steps, it's possible that there's a deeper software issue with your phone. In that case, you may need to contact Samsung support or visit a Samsung service center for further assistance.
4/16/2024 5:04:46 AM • Samsung Cell... • Answered 12 hours ago
Samsung Rugby 2 ( Rugby ii) A847 Two Tones, and Hard Case/Cover/Faceplate/Snap On/Housing/Protector Logo
42 questions posted
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cell Phones
  • Samsung Cell Phones
Most Popular Question
just got unlocked samsung rugby ii am
  • Cell Phones
