20 Most Recent Sony CDP-CX300 CD Player Questions & Answers
I took out all discs. When I tell it to play a disc the table moves back and forth slowly about an inch. After a couple trys "Table Error" shows up. Both belts are old but on.
Tray will prolly need retimed after the belts slipped off the pulleys. Procedure is with tray brackets removed lift tray in back then push open button to let the cam gear spin around to open position. Then let tray down and try to close it with button. Reinstall brackets and may take a few attempts to get that gear in the right position!
12/18/2014 4:11:55 PM • Sony CDP-CX300... • Answered on Dec 18, 2014
On my CDP-CX300 It will not play comes up with "Disc loading error" on the display, turntable and loading mechanism seems labored suspect power problem ? any suggestions ?
1. Chances are real good that the laser lens has gone out or is too weak to read the disk. It's a maticelous procedure to calibrate a laser lens. It may just need to be replaced. 2. The labored mechanism is due to the belt in the disk drive being dirty or stretched out. With this the mechanism can't inject far enough for the laser assembly to come up properly far enough for a good laser alignment therefore giving you the disk read error. You can clean these drive belts with alchohol and put them back in. While it's out check the belt for cracks. If there are any replace it. Or if it seems stretched out, which you can tell when it's around the pulleys, replace it. This belt is located in the front and under side of the disk drive assembly. I've had the same problem with Xbox360 drives and the above solutions worked out quite well. But I haven't worked on one of these devices yet. 3. As a last thought. There may be a swollen capacitor on one of the circuit boards that may be causing the problem. A cap swells and shorts out. If so it will need to be replaced. I've had single swollen caps keep an entire television from working.
11/30/2014 2:18:53 PM • Sony CDP-CX300... • Answered on Nov 30, 2014
Cx 300 won't read cd it says no disc after i replaced optical laser lens
If you have fitted a new laser assembly, have you removed the blob of solder that protects it while fitting, it's on the board underneath across two tracks
10/20/2014 10:28:56 PM • Sony CDP-CX300... • Answered on Oct 20, 2014
Getting no sound hooked up to pre-amp and 2 rotel 200w amps with snell speakers
You didn't say whether the player is connected by 2 RCA cables (analog) or by digital cable. If by RCA, does the player have a headphone jack? I had a player once with a piece of a headphone that broke off inside the jack, muting the analog outputs.
8/22/2014 5:38:25 PM • Sony CDP-CX300... • Answered on Aug 22, 2014
How can I buy the replacement belt?
I usually just clean the belt with alchohol or get a belt from another cdrom. I have yet to find a place to buy belts.
6/12/2014 3:00:25 PM • Sony CDP-CX300... • Answered on Jun 12, 2014
0answers
Mine did the same thing after being out of service for several months. I fired it up, ran beautifully for 6mos. Or so, then the "no disc" message appeared. The local I took it to said buy a new one...cheaper than fixing it. Sorry.
4/24/2014 7:30:44 AM • Sony CDP-CX300... • Answered on Apr 24, 2014
Replace belts
You can them from best buyer store on line . The only problem it take two weeks or more to get them
4/24/2014 12:52:11 AM • Sony CDP-CX300... • Answered on Apr 24, 2014
0answers
Sony cdp cx 355 displaying table error
What worked for me was taking the cover off and carefully threading a belt back onto a wheel. There are two motors at the back of the unit, one (I believe) that grabs the discs and moves them in & out of the player, and a second one that rotates the table (i.e., the round slotted thing that holds all the discs). The belt had simply slipped off the wheel that drives the latter. I did remove the back panel as well, to access it better, and inadvertently disconnected a sensor plug, which led to a second round of troubleshooting, but - in the end - I got it working!
4/21/2014 2:34:58 PM • Sony CDP-CX300... • Answered on Apr 21, 2014
Table error
hi I have a old fashion wizard jukebox,I need setting, for volume, free play, and play full cd,any help would be great many thanks john
11/9/2013 7:59:38 PM • Sony CDP-CX300... • Answered on Nov 09, 2013
Sony CDP-CX300 CD Player Logo
86 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
remote
  • Audio Players & Recorders
