20 Most Recent Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Questions & Answers
2answers
Dead KDf 60xbr950; 6 blinking red lights. I spent hours on research & would like 2nd opinions, please.
Not the board, there is a thermal fuse under the lamp housing that has opened up, you need to order an upgrade thermal fuse link that will mount to the Lightengine side of the lamp housing, the clips are there, there is no sensor there.
5/22/2019 12:59:47 AM • Sony Grand WEGA... • Answered on May 22, 2019
6answers
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
2/7/2017 2:17:59 AM • Sony Grand WEGA... • Answered on Feb 07, 2017
Cleanning projection tv
Have a yellow spot on right corner of picture on wega lcd
8/11/2015 4:14:48 AM • Sony Grand WEGA... • Answered on Aug 11, 2015
My red light flashes 5 times. whats the problem?
May need a new lamp, but most likely problem is the lamp fan. you can look through the back & see if the fan does come on, if not try to spin the blades, it may start running, but it will need to be replaced. You might also consider replacing the lamp, because if the fan has been a problem, that lamp has been overheating.
3/4/2015 6:49:49 AM • Sony Grand WEGA... • Answered on Mar 04, 2015
Mr. Peter I changed fuse 6.3 amp 125v from f board 6amp 125v from radio shake. is that make any difference.
you need to put fuse 6.3 amp to 6amp with same 125v if fuse not match or it will give problem
6/14/2014 3:54:20 AM • Sony Grand WEGA... • Answered on Jun 14, 2014
2answers
SONY KDF-60XBR950
The six blinks should have been the G1 board, double check your wiring and the check to make sure you have the 17V coming from the G1 board. If the problem has not changed it is possible you got a bad board.
5/29/2014 6:34:37 PM • Sony Grand WEGA... • Answered on May 29, 2014
I have a sony 60in that clicks when I turn on
Anything else? Red lights? Need additional info.
11/4/2013 11:36:33 PM • Sony Grand WEGA... • Answered on Nov 04, 2013
The power button is blinking red what do i do
Probably a bad lamp. Pull your lamp door and check the bulb. Usually obvious if it's bad (ie. shattered, blown tube) replace and enjoy!
11/4/2013 11:35:17 PM • Sony Grand WEGA... • Answered on Nov 04, 2013
Won't turn on
Additional info?? Blinking lights? Anything?
11/4/2013 11:33:37 PM • Sony Grand WEGA... • Answered on Nov 04, 2013
2answers
Tv light truns on green and then the red power
It might be a issue with the power supply, do you hear any strange noises or do you see any other led warning light?
8/2/2013 6:03:40 PM • Sony Grand WEGA... • Answered on Aug 02, 2013
What does 6 red blinking lights mean on sony projection tv
the lamp burnt out and need to be replaced my just like burnt out while i was playing zombies on call of duty and i can fell my controller vibrating so i got some downs, but um ya people say there's a door u can open, and u can basically open it and replay it, but people say i have to be careful of the glass i think its really fragile and you cant touch the glass when its hot, alot of people may not keep their manual for their T.V. so it may be hard to do it with out it. but yea ima try to fix mine and c what i can do well i hoe this helps u be careful fixing yo tv.
4/12/2013 5:47:30 AM • Sony Grand WEGA... • Answered on Apr 12, 2013
2answers
I have a 6 year old xbr have change the bulbs at
yes it is time to replace lamp again , this new lamp dont last long
4/4/2013 8:28:00 PM • Sony Grand WEGA... • Answered on Apr 04, 2013
I just changed the lamp,
Try replacing the thermal sensor as well.
2/28/2013 5:38:24 PM • Sony Grand WEGA... • Answered on Feb 28, 2013
Sony WEGA KDF-50E2000
I see you posted the model number but some idea of what the set is doing or not doing is needed and if a image issue try to post a photo of it here.
12/5/2012 4:47:54 PM • Sony Grand WEGA... • Answered on Dec 05, 2012
On the left side of the screen it is blue
do you have speakers close to it or on it move them away
9/3/2012 9:13:49 PM • Sony Grand WEGA... • Answered on Sep 03, 2012
How to replace thermal fuse
If you are looking to replace the thermal fuse on the set connected to the lamp reply so I can advise you.
8/17/2012 11:09:46 PM • Sony Grand WEGA... • Answered on Aug 17, 2012
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
166 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
problem theris no power supply try
  • Televison & Video
