20 Most Recent Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Questions & Answers
I Get a similar problem with my Philips TV, which I believe is a relay playing up. I find pulling the power and leaving it ten minutes usually discharged the capacitor holding the relay open and when I plug it in again, all is well. Had the issue for 3 years, it always works for me
Sony KP-46WT500... | Answered on Sep 22, 2015
you will need to trouble shoot the amplifier section which have bad capacitor or the amplifier get bad. if you don't have enough knowledge in repairing in electronics as will as tools and device as my advice just send it in the trained trusted tv repairman.good luck
Sony KP-46WT500... | Answered on Jun 14, 2014
The light is blinking a repeating error code. Try to determine the number of blinks before a slight pause as that will be an error code. Then respond to this same post and I will assist you with diagnosing what may be causing the set not to power up.
Sony KP-46WT500... | Answered on May 29, 2014
Pull the lamp out and with a flashlight look at back of the compartment. There should be a cutoff contact switch at the bottom where the lamp pushes it inward when connected. If you dont see this, it is possible you may have inadvertently pushed to hard when inserting the lamp and that switch has to be replaced. It is part of the projection engine/unit and unfortunately that will be expensive if that is the issue. Good Luck
Sony KP-46WT500... | Answered on Nov 21, 2013
Well after rechecking everything again and did some checking with help of some other emailers, I found a blown fues on the G board, that should fix my problem and maybe some others.
thanks
Sony KP-46WT500... | Answered on Nov 19, 2013
yes their is a built in tuner.
Sony KP-46WT500... | Answered on Jun 02, 2013
2x2" tweeters and 2x5 1/2" as for watts and ohms I can look and see
Sony KP-46WT500... | Answered on Apr 26, 2013
The set has 3 IC's(one for each color)strictly dedicated for the aligment of each color,if one them does not align is because is going bad or is already bad becuase picture can not be adjusted,the IC's can be identify because they are mounted on a heat sink and have the markings STK--- ---,they are all the same and need to be replaced with an exact replacement.If you are familiar with tv service you can replace them,sometimes the new ones need to be aligned from the service menu,you will need the service manual,soldering and unsoldering will be involved,If you are not too familiar be safe and seek the assistance of a servicer.
Sony KP-46WT500... | Answered on Mar 07, 2013
Check the speakers with a meter (like checking a fuse--the ones in this set are fairly standard and will have ohms and wattage marked on them.
Rather unlikely both would fail and if they test good you may want to see they did not get switched to OFF in main menu.
There is a reset but try these suggestions first.
Sony KP-46WT500... | Answered on Dec 02, 2012
Try using the MENU button on your remote control to go into the TV picture settings menu. Change the mode to NATURAL, You can also try to manually adjust the color in the COLOR SETTINGS mode.
If that doesn't work, check out the handy troubleshooting chart in TV color problems and see if another solution will work. I hope this helps!
Sony KP-46WT500... | Answered on Sep 20, 2012
The power indicator should blink a series of blinks pause slightly the keep repeating the blink sequence. let me know the blink sequence and I can let you know why the set is shutting down.
Sony KP-46WT500... | Answered on Aug 05, 2012
follow power cord (set unplugged) to power board and the glass fuse there--check it first.
Sony KP-46WT500... | Answered on May 22, 2012
Did you replace the pico fuses on the G board there are two and usually one will blow when the old ICs fail and just replaceing the two ICs on the D board will usually not fix the issue untill the two pico fuses are checked and the blown one is replaced.
Sony KP-46WT500... | Answered on Mar 21, 2012
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Sony KP-46WT500... | Answered on Mar 09, 2012
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
295 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
needs new speakers
  • Televison & Video
