20 Most Recent Toshiba PDR-3310 Digital Camera Questions & Answers
manual
I lost my disk for my toshiba camera and cant get
You can download your software here at this site.
http://download.driverguide.com/driver/PDR-3310/Toshiba/d383757.html
Good luck and please rate.
9/10/2009 5:48:26 PM • Toshiba PDR-3310... • Answered on Sep 10, 2009
3answers
Power issue
replace the battery in such issues.
12/1/2008 9:30:40 PM • Toshiba PDR-3310... • Answered on Dec 01, 2008
Help on PDR-3310 can not power on and no displace on LCD
Push lens assembly back into camera gently yet firmly with your thumbs until you hear a click.
12/1/2008 9:04:22 PM • Toshiba PDR-3310... • Answered on Dec 01, 2008
Unable to install Driver on my WIN XP
No driver needed. Plug in camera via usb to computer. The memory card will show up as a drive under my computer. NO DRIVER IS NEEDED....
10/17/2008 4:34:50 PM • Toshiba PDR-3310... • Answered on Oct 17, 2008
Download for drivers for Vista
Sorry, but we are all screwed with the Toshiba PDR-3310. They discontinued the camera and never upgraded to Vista so if you can even find a fix for the XP version, good luck. It seems that Toshiba does not want to provide any assistance or customer service when it comes to their products that are older.
8/23/2008 2:35:25 AM • Toshiba PDR-3310... • Answered on Aug 23, 2008
2answers
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
6/14/2008 9:48:26 AM • Toshiba PDR-3310... • Answered on Jun 14, 2008
Better Focus
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Be sure not to use Macro Mode for Normal Photography. Using MACRO MODE improperly will result in poor focus (also known as 'fuzzy pictures'). 4. Rely on the LCD Monitor, especially for Telephoto and Macro photography. Due to differences in depth perception, the Viewfinder is not as accurate at the LCD Monitor. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
9/11/2005 12:06:54 PM • Toshiba PDR-3310... • Answered on Sep 11, 2005
Card Error Message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. The Toshiba PDR-3310 is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. The PDR-3310 may work with some MultiMedia Cards, but is not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
9/11/2005 12:01:15 PM • Toshiba PDR-3310... • Answered on Sep 11, 2005
My Toshiba Camileo HD-DV Camcorder won't focus
If your Toshiba Camileo HD-DV camcorder is not focusing properly, there are a few potential causes and solutions to try:
  • Check that the lens is clean and free from any smudges or fingerprints. Even a small amount of dirt or debris on the lens can affect the focus. If the lens is dirty, try cleaning it with a lens cleaning solution and a microfiber cloth.
  • Make sure the lens is not blocked by any foreign objects, such as the hood of a camera bag or the edge of a cap.
  • Try adjusting the focus manually using the focus ring on the lens. If the focus ring is not responding or is difficult to turn, the lens may need to be serviced.
  • Make sure your camcorder firmware is up to date. Check Toshiba website to see if there is any update available and instructions on how to update.
  • Make sure the camera is not in macro mode. Some cameras have a separate macro mode that enables the camera to focus on objects that are very close. If you are not trying to take close-up shots, you may need to switch out of this mode.
  • Make sure the scene is well lit. Low light can make it more difficult for the camera to focus, try adding more light to the scene or use the manual focus.
If none of the above steps work, it is possible that the camera's autofocus system may be malfunctioning and will need to be repaired. It's best to contact Toshiba customer service or a local camera repair shop for a diagnosis and estimate for repair if the issue persists
1/12/2023 12:35:19 AM • Toshiba Cameras • Answered on Jan 12, 2023
How does is the right setting of Toshiba refrigerator display setting
This is not a camera. Why post in the Camera queries forum ?
12/8/2021 11:25:12 AM • Toshiba Cameras • Answered on Dec 08, 2021
Toshiba tv 43u2963db
a) This is not a camera b) Have you looked in the manual ?
11/30/2019 12:00:25 PM • Toshiba Cameras • Answered on Nov 30, 2019
I have a Toshiba PDR2300. I get card error and can't take pictures. How do I fix this?
Discover what the error is with the card and correct it. The card could be corrupted, an incorrect storage capacity, write-protect could be set, or it could be full.
4/8/2017 12:00:53 AM • Toshiba Cameras • Answered on Apr 08, 2017
I'm having a problem with
As you yourself have said, this is NOT a camera. For help, I would advise you to post this in a forum dealing with computer equipment.
3/10/2017 11:42:30 AM • Toshiba Cameras • Answered on Mar 10, 2017
I need a price check on a Toshiba CMOS digital still. Camera price check please
Fixya does not offer advice on pricing equipment. Check on Ebay to see how much similar items are being advertised for.
12/16/2016 9:14:30 PM • Toshiba Cameras • Answered on Dec 16, 2016
Toshiba PDR-3310 Digital Camera Logo
10 questions posted
Top Toshiba Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
View Most Popular
Toshiba Cameras
  • Toshiba Cameras
Most Popular Question
lost disk toshiba camera get
  • Cameras
