20 Most Recent
Toshiba Sora PDR-T30 Digital Camera Questions & Answers
Toshiba Card Error
Try formating the card in the computer.
This can be done with windows explorer, just right click on the drive that the card is in, a menu will pop down and click format, then start.
Hope this helps.
Focus
There are several factors that can contribute to getting better focus and improved results.
1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. This process usually takes about two to three seconds.
2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls.
3. Only us the MACRO MODE for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Be sure not to use Macro Mode for Normal Photography. Using MACRO MODE improperly will result in poor focus (also known as 'fuzzy pictures').
4. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Resolution
To set the resolution just Press the MENU icon (middle icon) on the left side of the LCD screen. Then press the QUALITY icon (lower row left icon). Choose from one of the four icons.
Erase Images
Press the trashcan/folder icon to erase a single image. Press and trashcan/mulitple folders icon to erase many images, all images, or to format the SD Card. It is good to Format the SD Cad from time to time after downloading the images to clear all residual memory files (even if you do not see them).
My Toshiba Camileo HD-DV Camcorder won't focus
If your Toshiba Camileo HD-DV camcorder is not focusing properly, there are a few potential causes and solutions to try:
- Check that the lens is clean and free from any smudges or fingerprints. Even a small amount of dirt or debris on the lens can affect the focus. If the lens is dirty, try cleaning it with a lens cleaning solution and a microfiber cloth.
- Make sure the lens is not blocked by any foreign objects, such as the hood of a camera bag or the edge of a cap.
- Try adjusting the focus manually using the focus ring on the lens. If the focus ring is not responding or is difficult to turn, the lens may need to be serviced.
- Make sure your camcorder firmware is up to date. Check Toshiba website to see if there is any update available and instructions on how to update.
- Make sure the camera is not in macro mode. Some cameras have a separate macro mode that enables the camera to focus on objects that are very close. If you are not trying to take close-up shots, you may need to switch out of this mode.
- Make sure the scene is well lit. Low light can make it more difficult for the camera to focus, try adding more light to the scene or use the manual focus.
If none of the above steps work, it is possible that the camera's autofocus system may be malfunctioning and will need to be repaired. It's best to contact Toshiba customer service or a local camera repair shop for a diagnosis and estimate for repair if the issue persists
I'm having a problem with
As you yourself have said, this is NOT a camera. For help, I would advise you to post this in a forum dealing with computer equipment.
