Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the
picture to look normal. This is called convergence.
When its out of alignment the video will look
3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the
time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection
TV sets including
Sony,
Samsung,
JVC,Philip
Magnavox,
Panasonic,
Akai,
Pioneer,
Hitachi,
Mitsubishi,
Zenith, RCA and others.
You can
get more information and a DIY convergenece repair kit with instructions from
TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks
3-D *Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video -
TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking
picture *White looking
picture *Halos around objects
*Red/Orange looking
pictureSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
