20 Most Recent
Sanyo Incognito 6760 Questions & Answers
Hat code is Netflix activation asking for?
In order to watch Netflix on your Netflix enabled device you will need a computer with internet access, an internet connection for the device itself, and a Netflix subscription.
- Open your preferred web browser on your computer and navigate to www.netflix.com
- Log into your acct if necessary and click "Your acct & Help" on the upper right hand side of the page
- Scroll down the page until you reach the "Watching Instantly on your TV or computer" section and click the link for"Activate a Netflix ready device"
- On the device itself, navigate to the Netflix App (location will vary based upon model-please see your manual for specifics)
- After launching the app for the first time, you will be asked if you have a Netflix acct. When you answer "Yes", you will be given an authentication code that you will then need to enter on the page you should now be at on your computer.
- Click the "Activate" button after entering the code on the "Activate your Device" screen from your computer.
Netflix will now link your device and your acct; you will see a confirmation message on your computer when successful. You should now be viewing your Netflix home screen on your device. Select a title to begin streaming.
When ever i try to charge my phone it wont
Hello there,
Have a nice day.
You have mentioned the you have bought a new charger and a new battery but still your handset wont charge.
The problem is from the charging port on your phone. You will need to change or replace the charging port on your phone to fix the problem.
Try to take your phone to any Sanyo service center or any local phone repairer to help you replace the charging port, it has a minimum charge only.
Hope it helps,
Thank you for using the fixya.
Adieh
How do i hard reset
Hi.
1)Power off the phone
2)hold the volume up button+ the send button and turn the phone on and ............Reset.
I hope this helped you.
Thanks for using fixya
Scp-7050. Where is SIM?
I don't think that type of phone uses a Sim card. It uses a separate network system used by some commercial businesses.
