20 Most Recent
Sony KP-61V90 61" Rear Projection Television Questions & Answers
Convergence ?
IF THE COLORS ON SCREEN ARE SEPARATED, OR BLURRY, OR YOU SEE SEPARATE COLORS ON SCREEN. DO A GOOGLE SEARCH AND YOU SHOULD FIND CONVERGENCE PROBLEMS ON TV'S AND WHAT IT LOOKS LIKE. THERE ARE CONVERGENCE KITS AND EASY INSTRUCTIONS.
My t.v. led is bling on timer and standby
tried to disconnect the ac supply to the tv for a while. then plug it again and power it on hope it will back to normal. you can use the remote control then turn off the timer.
Screen to dark
The 3 large lens (which can clearly be seen on Model indicated here can be cleaned) Look first to the lens and on this set from rear look up and inside at the mirror in the rear---lens are more common than the mirror.
A chip on the circuit board started smoking
The component sounds like a resistor, and the fact that it was attached to a heat sink means its a power handling resistor. You said it was burning, so this means that whatever it is attached to is drawing too much current. From what you are saying a component on a board is drawing too much current and is causing another component (the 1 ohm resistor) to burn. My question is what board is this (I am suspecting the deflection or the HV power supply). Please post a picture of the board in question. That way I have a visual guide as to the board and if I can find the schematic, or if you can supply the schematic I'll be able to at least give a better diagnosis of this problem.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
My sony kp-61v90 tv picture
Hello, It sounds like the deflection circuit is faulty. Usually,but not always caused by a problem with the switch mode power supply. It could be as simple as a capacitor or zener diode. Either way unless you are a technician I would get one to help you. Shouldnt cost any more than around $100-$180. As far as the pix goes,that sounds like the lamp they use to project images,around $400 fitted. Hope that helps.
My Sony KP-61v90 has just
This set should have 2 RF inputs. Try hooking up to the B input and program the tuner again...
Let me know how that works for you.... Sincerely HDTV GURU JAY
