20 Most Recent True 31 cu. ft. / 878 liter Commercial Freezer TR-31F Questions & Answers
Unit freezes but does not come back on sometimes
Check the time clock
11/3/2010 8:56:54 PM • True 31 cu. ft.... • Answered on Nov 03, 2010
The inside of unit is
Start off by cleaning the condenser coils. If you get up on a step ladder or chair look for the radiator in front of a fan. This radiator gets hot when running. If the air flow is stopped by dust or grease in the coils ther freezer will not work properly. Be sure the fan is running also whenever the compressor is running. The next most common problem is that the inside coils are frozen over. Your unit must defrost 3 or 4 times per day. When the door is opened frost accumulates on the inside coils and will eventually cover the coils with ice if your defrost cycle is not working. If the coil freezes over the temperature will go up, the compressor will continue to run and it the temperature will continue to increase. Check the inside coils for ice. If there is ice, you will have to unplug the unit and let the ice thaw completely before restart. If the unit pulls down to 0 after restart, it was probably frozen over. If that is the case you will need to either increase the number of defrost cycles or verify that the defrost cycle is working. Try this and repost if that does not resolve your problems.
9/23/2010 2:47:10 PM • True 31 cu. ft.... • Answered on Sep 23, 2010
I have an AHT Salzburg chest freezer and it's
pull the plug and let it defrost. ck the drain for water. it maybe pluged. after 2 to 4 hrs. plug it back in and set the temp. to -10 degrees f . fill small dish or bowl with water and see how long it take to freez. if it takes longer then 4 hrs you may need freon or have a compreesor problem, or defrost timer .
8/24/2010 7:28:20 AM • True 31 cu. ft.... • Answered on Aug 24, 2010
I have a freezer true
Before you do, consider these items:
1.) You will need to replace the compressor (Most likely). Compressors are sometimes rated for medium and low temp applications but not always.
2.) You may also need to replace the evaporator. They are rated by BTU's and what you have most likely will not work as you are changing the temp range.
3.) You will need to disable the defrost control and heater.
4.) You will need to bypass the fan delay or remove all together and reconfigure the wiring for such.
5.) You will need a new expansion device. Be it a cap tube or TXV, it still needs replacing as you are changing the temp range and BTU's you want.
6.) You will most likely need to replace the temp control (t'stat). Again, different temp range.
7.) Now, figure in the labor it takes to do all this. (Including the research to see it these items will work or not.
You may want to rethink doing this and opt for another piece of equipment.
Anyway, these are the steps you will need to take if you want to do the conversion.
Hope this has been of some help.
6/11/2009 1:16:31 AM • True 31 cu. ft.... • Answered on Jun 11, 2009
Can I convert an existing refrigerator to a freezer ?
It's do-able but really not worth the money it would take to do it. You would most likely have to change out the entire refrigeration system (compressor, evap., and expansion device.) Then you would have to add some sort of defrost timing device and defrost heaters. This woud include an defrost terminator and fan delay device as well. Way too much work and money to get what you want.
I would try to shop around too see if you can pick up a good used one from a reliable source.
Good luck and hope this helps.
4/17/2009 2:00:23 AM • True 31 cu. ft.... • Answered on Apr 17, 2009
2answers
Convert freezer to refrigerator
Converting a freezer to run like a fridg can be done ,however it is sometimes tricky. you have to replace the thermostat, you will also want to shorten the defrost time setting. and may have to disable the fan delay to let the evaporator fans run all of the time, to prevent short cycling of the compressor.
3/7/2009 4:53:48 AM • True 31 cu. ft.... • Answered on Mar 07, 2009
True T-49F 55? 2 Door Solid Reach In Freezer. How to solve error code E1 on freezer Tru T49f?
Question edited for clarity. Question moved to maker category. Thermostat Probe Error
E1 error on a true freezer. True Freezer, 5yrs. Just
JustAnswer https://www.justanswer.com > Appliance Repair Mar 6, 2022 - Ok. The E1 error code indicates a thermostat probe failure. 1 answer · Top answer: Hi, welcome to JustAnswer. My name is***** am a ticketed HVAC and refrigeration technician with ...
True Refrigeration Troubleshooting
Parts Town https://www.partstown.com > resource-center > guides P1 Alarm/ E1 Code. What does it mean? - This indicates a thermostat probe failure. "P1" displays on units with Dixell electronic controls. "E1" . ..
4/12/2024 3:24:01 PM • True Freezers • Answered on Apr 12, 2024
True T-23F Single door freezer. My freezer isn't running?
Question edited for clarity and better English. Low on Refrigerant Gas. You need a refrigeration engineer.
10/12/2023 3:39:09 AM • True Freezers • Answered on Oct 12, 2023
True T-49F 55", 2 Door Solid, Reach In Freezer. It sounds like it is one but it is not getting even cool? True Freezer.
Question edited for a lot more clarity. Question moved to True Freezer category. You need a refrigeration engineer. It sounds like is has a leak and needs topping up with refrigerant gas. Things that also need checking, circulation fan working and that the defrost timer and defrost heater, and electronic thermostat are working correctly. Refrigeration is not a handyman job. ..
4/14/2023 4:33:18 AM • True Freezers • Answered on Apr 14, 2023
My true freezer will not freeze...everything turns on but tye fan inside....please help!!!
Your fan it's either defective, Or your unit is frozen up and the fan is stuck in ice. Unplug it defrost it take off the panels and see if the motor's any good .
6/2/2022 5:08:58 AM • True Freezers • Answered on Jun 02, 2022
2answers
No door heat
The Mulluen heaters will be Built into the frame not in the door.
1/10/2022 5:01:22 PM • True Freezers • Answered on Jan 10, 2022
I have true freezer t-19 that's not getting cold.it turns on but that's about it
we are not freezer repair tech , call one local to you
5/31/2021 9:44:39 AM • True Freezers • Answered on May 31, 2021
On freezer True T-23, the compressor works around 5 minutes and turn off for around 5-6 minutes and start again for another 5 minutes. I need help
That is what it is supposed to do. It is called cycling and switches off when the set temperature is reached. It is a commercial freezer, so if the door opened and closed often, that is normal?Commercial freezers and fridges have an item called a 'Clixon' that cuts power in the case of the compressor overheating. When was the last time the fins on the compressor coils were cleaned? Could also be a bad door seal letting cold air escape. When you close a freezer door on a unit like that, it should be really hard to open straight afterward due to the suction. Could be a faulty thermostat. Turn the temperature to the warmest setting and see if it still does it? If it does, you need a new thermostat.I just retired after 52 years in catering.https://www.katom.com/598-T23F.html?gclid=CjwKCAiArbv_BRA8EiwAYGs23PKtEzF60_OMVNpHXBlGjHQNdpp0pDZsu0G0lFLqVy2p4qIybG9n8xoCwEMQAvD_BwE..
1/1/2021 9:38:12 PM • True Freezers • Answered on Jan 01, 2021
Why is jenn air jcd2389ge hot around front freezer door frame?
The heat at the opening of refrigerator is usually a sign the condenser coils are dirty. Check the condenser coils for a restriction underneath the unit. Dirty condenser coils will cause poor air flow over the coils and compressor. Poor air flow will cause a lot of problems, including overheating the compressor, the refrigerant and the copper lines. This will destroy your sealed system. The coils need cleaning at least once a year, more often if you have pets.
I couldn’t determine if your unit has an “energy saver” setting. If so, turn it on. Not all refrigerators have energy saver. This is on units with emilion heaters in the wall around the door gaskets. The heaters are to eliminate condensation around the door. Turning ON energy saver turns OFF those heaters. You should notice a change quickly if it’s the heater causing the heat, that is, if you have that model.
Cleaning the coils will need a day or two to allow things to cool down before you notice a change in the heat around the door.
7/29/2019 4:27:08 AM • True Freezers • Answered on Jul 29, 2019
Can the temperature be adjusted on the true GDM-49F
https://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/TRUE-GDM_iom.pdf Here is the site for the ops manual. should walk you thru how to do temp adjustments.
11/19/2018 11:10:04 PM • True Freezers • Answered on Nov 19, 2018
True 49f fans stopped running. Compressor still runs. Fixes? Troubleshooting steps?
I am assuming you are relating to the evaporator fan(s) not running. If this is the case, some units have a 'Klixon" type thermostat in the evaporator so when the evaporator coil temp reaches a predetermined temperature, the fans come on. You may have a bad "Fan Delay" (Klixon) or the coil is not reaching the proper temp to activate it to turn on the fans. I would check the wiring diagram on the unit for this part to see if this unit has it in the system.
6/12/2018 12:18:22 AM • True Freezers • Answered on Jun 12, 2018
True 31 cu. ft. / 878 liter Commercial Freezer TR-31F Logo
Popular Tags
8 questions posted
Top True Freezers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a True Freezer Expert? Answer questions, earn points and help others
View Most Popular
True Freezers
  • True Freezers
Most Popular Question
convert existing refrigerator freezer
  • Freezers
