20 Most Recent
Sony KDE-50XS955 50 in. Plasma HDTV Questions & Answers
What's wrong with it?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Pink Screen
check all your cables & connections & connections at I/O ports; possibly I/O PCB
We just got a new
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
Have KD- XS955 50 inch.
Component problem. A defective component on the power supply circuit causes these symptoms ma'am/sir. You need an electronic servicing technician to do the work.
TheTV made a loud pop
You probably blew up a capacitor. Unplug the television and open up the back. Check for bad caps. You'll probably find a puffy one. Check the fuses to see if they're blown. If you find a blown fuse, start looking for bad diodes or a bad transistor. If you don't know what I'm talking about then don't ruin a good television set by poking your nose inside and blowing something else up or end up zapping yourself when you touch the wrong thing. Take it to a professional and get it fixed. Good luck.
Fails to start up
Without being able to see the TV or take measurements when it does not turn on, my best "guess" would be the A2U board, which has most of the power supply components. This is only a guess, you really need a tech to take some measurements when it doesn't come on. I would like to get in touch with you to have you check some items using the original remote control. Do you have Yahoo messenger?
Tv prob
There is a sleep setting, similar to a snooze butting on an alarm clock, and it can be found in the Time Menu. Just turn it off, and the set should work fine.
Good luck.
Sleep timer not a fix
This Tv is a piece of junk I have 2 of them and I had to replace the first one with this same problem. The second one just broke is stuck in dvd mode. Company is out of buissness
