20 Most Recent Sony KLV-S19A10 19 in. HDTV-Ready LCD Television Questions & Answers
Ur lamp is dead,replaced the lamp.
Sony KLV-S19A10... | Answered on Feb 17, 2010
Please try the steps provided below and check if that helps.
Press the WEGA GATE on the Remote Control.
Then, select the SETTINGS option in the Menu.
Then, select the AUDIO Settings.
Then, set the STEADY SOUND option under the Audio Settings to AUTO.
Also try changing the MTS Setttings under the Audio Settings.
Sony KLV-S19A10... | Answered on Jun 18, 2009
Could be the motherboard, or a fuse. Without having it in hand it is hard to tell what it is. Check to see if there is an inside fuse in it.
Sony Televison &... | Answered on Dec 07, 2019
That is because it is a DVD controller, not a TV controller.
Sony Televison &... | Answered on Dec 05, 2019
You will find it if you google it.
Sony Televison &... | Answered on Dec 01, 2019
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter.
2 red flashes is bad power board, solution replace power board or repair it.
Possibly tv reach its end. Save money and replace it with modern energy efficient tv.
Unless your Sony remote control is programmable, you are unlikely to be able to find a code for your Sansui TV.
Sony Televison &... | Answered on Nov 27, 2019
Use code search on your GE URC to find something that works. If a search through all codes contained in the URC fails, try a different one.
Hi Daya,
It is a panel fault. It can be repaired. But it is a tricky and risky job. To attempt this repair you need to be an experienced technician. If you are a technician, please let me know. I will give you the details.
Sony Televison &... | Answered on Nov 23, 2019
Sony KLV-S19A10 19 in. HDTV-Ready LCD Television Logo
Popular Tags
8 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
S Sony
  • S Sony
Most Popular Question
when turned red light blinks four times
  • Televison & Video
