20 Most Recent
Sony KLV-S23A10 23 in. LCD HDTV Questions & Answers
Sony KLV-S32A10 LCD TV background
You either have a malfunctioning LCD controller(T-con) or the panel itself is faulty. The T-con is very inesxpensive and easy to replace but the panel is gonna cost you nearly as much as a new tv. Let me know if you want to give the t-con a shot so that I can guide you to fix it.
WHEN I FIRST TURN ON TV ALL I GET IS VERTICAL
this may be a problem on the 5 volt line in the set, there is a constant 5 volts running through it even when it is off....so long as its plugged in.
There may be condensors that are open on the 5 volt line.. after they warm up they start to function more proper. but being that they are leaky..they are no longer doing thier job of keeping voltage steady until they warm up.
i do not condone this but if you were to open it up , im willing to bet you have a series of swollen or blown condensors that are not doing thier job on the pwb (power supply board) if thats the case its a 30 minute fix for a technician. Id like to discuss this with you further , i do have a couple questions that may help me diagnose this.
When first turned on the TV works normally - then
Good day sir/maam, the trouble is caused (possibly) by the failure of the IF amplifier system of your TV, it is usually sets of transistors, or an IC that controls the gain of your TV. Have your service repair man check the section fro the tuner stage to the IF stages. chances are the IC is not functioning properly. Hope this helps.
Input 5 not playing audio via HDMI or stereo
HDMI can be problematic. Follow these steps in order for the best success with HDMI.
1) With all devices off, turn the TV/monitor on first and wait for it to come on.
2) Select the HDMI input.
3) Turn on the next HDMI device (stereo amp if it comes before the video device, or the video device itself and let it come on.
4) Play the video.
Some video devices may need the audio output to be set to PCM or 48k/96k datastream to work correctly.
If this doesn't help, you may have a compatibility issue with your HDMI device. Usually it is the fault of the player/video receiver and rarely the display/TV. All the TV/monitor does is query the source device as to what type it is and the resolutions it's supports.
Hooking up external speakers to my bravia
You have to conected it to the line out audio. In the back of your tv will be says "Audio Out" conect it with the red and white cable to your rca seround system and press "Aux" button on it.
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
