20 Most Recent
Sony WEGA KE-42TS2 42 in. HD-Ready Plasma Television Questions & Answers
Sony Bravia LDL-46br3 LCD 1080hd, TV keeps shutting off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
2/17/2018 10:43:17 AM •
Sony WEGA...
Answered
on Feb 17, 2018
How to clean a plasma
Warm soapy water with mild detergent (like dish soap) on a damp cloth, then rinse with a clean water dampened cloth.
4/30/2012 1:48:45 PM •
Sony WEGA...
Answered
on Apr 30, 2012
I have a Sony plasma
here is a link to the perfect bracket for this plasma. it has everything needed and is what i use to install a 50 in sony the other day.its carried in walmart stores to
http://www.google.com/url?sa=t&source=productsearch&cd=2&ved=0CF0QgwgwAQ&url=http%3A%2F%2Fwww.walmart.com%2Fip%2FLevel-Mount-Fixed-Mount-Fits-34-65-TV%2F10056403%3Fsourceid%3D1500000000000003142050%26ci_src%3D14110944%26ci_sku%3D10056403&rct=j&q=walmart%20wall%20mounts&ei=TnmCTc68E4O4tgfGh6XWBA&usg=AFQjCNH0dJF90t9G9MeTKS6gcbdk0WOYLw&sig2=84aML2R7KxsHAfYi3M9P0Q&cad=rja
i also like this model as well
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4318066&CatId=2462
3/17/2011 9:13:21 PM •
Sony WEGA...
Answered
on Mar 17, 2011
HI THERE
I HAVE A SONY KE-32TS2 PLASMA TV. I
The light gray screen signals that there is no signal coming to the image processor. This means that the tuner board you just installed isn't operational. And since the tv doesn't respond to the remote commands (you have surely tried the buttons on the case with the same result) means that the control processor isn't functioning : you will have to reseat all connections between he boards of the tv and check the status of the mainboard - maybe something got disconnected.
12/22/2010 8:33:25 PM •
Sony WEGA...
Answered
on Dec 22, 2010
Screen message- channel fixed. how do I get it to
If you are on a sat system then you only need one channel programmed, if you are using the cable input, if you just want the channels scanned for a local antenna, then you need to go to the menu and go to programming and change the cable/ant to ant and program.
12/13/2010 11:06:33 PM •
Sony WEGA...
Answered
on Dec 13, 2010
Screen display says channel fixed,
Hello
Your TV has channle fixed at advanced setting options.
To select this option "Press Menu" and "Press Up or Down" button to select "Channel Fix". A Yagi Antenna symbol" will be displayed, when this option is selected.
Select this when you have a cable bod or satellite reciver connected.
2-6: select this to "fix" your TVs channel setting to 2-6 and use the cable box or satellite reciver to change channels. Select one of these settings if you have connected the equipment to the VHF/UHF JACK.
Video-1: Select this if you have connected the equipement to to the AUDIO and VIDEO IN jacks.
Select "Off" to turn off the "Channel Fix" feature.
When you select "channel fix", the favorite channel cannot be used.
When you select "channel fix", you cannot use Channel Skip/Add or autoprogram in the TV setup menu. To use them, select Channel Fix to :Off".
Ok.
12/13/2010 4:12:32 AM •
Sony WEGA...
Answered
on Dec 13, 2010
I have a sony ke-32
Its possiable the Part you replaced did not hold up,I would return that Part get New one and see if that FIXs the problem .
Encompass Parts Distribution has Free Service Manual for this Model.
You might want to Look at Shopjimmy.com for Parts for this set.
11/16/2010 12:09:02 PM •
Sony WEGA...
Answered
on Nov 16, 2010
My 2003 Sony Plasma television gets no screen. I
Check all the video inputs. If non of the inputs of video work you need a new Q board, However if your screen doesn't work at all shows no signs of life and you can't access the menu then you will need a new B board.
4/10/2010 3:10:33 AM •
Sony WEGA...
Answered
on Apr 10, 2010
Sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
4/7/2010 9:43:35 PM •
Sony WEGA...
Answered
on Apr 07, 2010
